how do i make my bird handle better?
Old Feb 4, 2007 | 10:50 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
ok, ive got an 86 firebird, v8, 5 spd, I found an iroc parts car, what parts should i ask for off it to make my car handle alot better?
Old Feb 5, 2007 | 05:52 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Grab the Wonderbar. I question whether it'll help with performance, but it will strengthen the steering box area.
JamesC
Old Feb 5, 2007 | 01:02 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
grab the front and rear sways too.......
Old Feb 5, 2007 | 01:39 PM
JamesC's Avatar
FYI. Some Camaros, 89-92, had the 36/24 combo; some Firebirds were equipped with that combo, 86-92.
JamesC
Old Feb 5, 2007 | 08:30 PM
Engine: 2002 Ls1
Transmission: t-56
the car im looking at is an 87, should i take the shocks, struts, sways, springs? are the shocks on those coil overs? wonderbar? is that the panhard rod? where is it located?
there is also an 85 iroc are the parts the same on these?
Old Feb 5, 2007 | 09:11 PM
krisb410's Avatar
No 3rd gens came factory with coilovers.
Only take the shocks and struts if they are better than yours.
The wonderbar is located between the sway bar bushings and the car, and don't bother with the factory panhard, only grab it if it's aftermarket. If both cars have the wonderbar, grab both and sell the other one.
I would compare the sways on the 2 parts cars, if they are bigger, then grab them. If both cars have bigger sways, then grab them and sell them.
Unless the springs are new, leave em, they are prob originals.
Old Feb 5, 2007 | 09:59 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
I would grab the Iroc springs. Also if it has an L98 you know what to do.
Old Feb 5, 2007 | 10:07 PM
krisb410's Avatar
If the springs are original, leave them after 20+ years, they are prob sagging and wore out. And replacement springs are not that expensive.
Old Feb 5, 2007 | 10:48 PM
Engine: 2002 Ls1
Transmission: t-56
thanks for the advice, ill definitly take the sway bars and wonderbar. are the disk brake rear ends worth grabbing? how much power will they handle? 7.5 10 bolt right?>=\\\
Old Feb 6, 2007 | 05:08 AM
JamesC's Avatar
Like Kris mentions, I'd measure the sways since your car may have larger sways than the IROC's in those years. My 85 IROC, for example, was originally equipped with a 34/24 combo. If you wish to upgrade to discs, to a better ratio, or to a posi, then check out the rear ends. The 10-bolts aren't known for their strength.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
bdads
Aug 24, 2015 06:01 PM
Catcher55
Aug 15, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
