creaking nosie???
Old Feb 17, 2007 | 04:40 PM
Skull88's Avatar
Car: 1987 Camaro Z-28
Engine: 305 cu. in.
Transmission: Automatic
creaking nosie???
I have a 87 camaro, and every time i trun the wheel it makes a creaking/popping sound, does anyone know what is it or what new part do i need to buy.
Old Feb 17, 2007 | 04:56 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Where is the sound coming from? Is it low speed turning? If it seems to be coming from the strut towers, your mount bearings could be bad, which is one explanation for noise while turning. It it's high speed turning, could just be the unibody.
Old Feb 18, 2007 | 04:54 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
does it only happen when the wheel is cut all the way to one side or the other? that happens in my 89 TA
Old Feb 18, 2007 | 06:28 PM
Skull88's Avatar
Engine: 305 cu. in.
yes it happens when i'm driving slow, and also it does it to one side
Old Feb 18, 2007 | 10:03 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
which side? lol
Old Feb 19, 2007 | 12:20 AM
sully91rs's Avatar
Car: 91 RS, 95 Z28
Engine: 305 tbi, 350 lt1
Transmission: 4l60, 4l60e
Axle/Gears: monsterous 2.73s in both
Check your sway bar endlink bushings. When the bushings wear away, its nothing but bare metal connecting the control arm to the sway bar. Mine made horrible popping and rattling noises until I replaced the endlinks.
$5 each, and it will also make your car handle MUCH better.
Old Feb 19, 2007 | 05:50 AM
95z28bill's Avatar
Could be a front lower control arm bushing also, but I tend to agree check your end link
Old Mar 1, 2007 | 09:30 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I have rebuilt my entire suspension. I get the same noise from the front passenger side area. At first I thought it was the spring moving around, then I thought maybe a ball joint. I also wondered if the welds on the SFC's have broke. Everything is new. Mine does it at slow speeds, like going into a parking lot. Not trying to high jack your thread, just trying to help.
Old Apr 4, 2007 | 03:12 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: creaking nosie???
Same problem i had. Rebuilt the front end...Turns out its coming from the PS Gearbox. The one thing i havent got to yet...LOL
sjorgens
Oct 1, 2015 07:54 PM
TomP
Mar 7, 2008 01:41 PM
Connan1
Sep 12, 2002 10:57 PM
86IROCZ
Aug 9, 2002 08:56 PM
