JUST PUT IN LOWERING SPRINGS... BUT ITS NO LOWER??
Old Apr 5, 2007 | 09:18 PM
CAMAROJOKESTER's Avatar
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
HI.. I JUST BUT IN SOME SPORTLINES IN MY CAR TODAY AND IT SITS REALLY HIGH... I HAVE 17 ON THE FRONT AND 18 ON THE REAR.. I WAS WONDERING IF I BUT THE SPINGS IN UPSIDE DOWN.. I PUT THE FLAT SIDE UP SO IT MADE THE WRITTING ON THE SPRINGS THE RIGHT WAY(NOT UPSIDE DOWN). I ALSO MADE SURE I COVERED THE TWO HOLES UP ON THE LCA. DO I NEED TO WAIT FOR THEM TO SETTLE OR WHAT.. PLEASE HELP.. THANKS
Old Apr 5, 2007 | 10:15 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
Re: JUST PUT IN LOWERING SPRINGS... BUT ITS NO LOWER??
AFTER READING I GUESS ITS NOT SEATED RIGHT.....BUT WHERE DO I GET THE SPRING ISOLATORS AT????
Old Apr 5, 2007 | 10:57 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
did you move the car at all, after you installed the springs?? if you didnt, go for a drive up and down the driveway.. if not, idk whats wrong..
the front springs should be flat(er) side up and the regular, cut-off looking side down.. there is only one way to put the rear springs on.. big end up and small end down..
Old Apr 6, 2007 | 01:26 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
well yes the springs will settle a little bit but you car probably had stock springs that were sagging anyway so it might not make that big of a diffrence
Old Apr 6, 2007 | 01:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
When I installed my Eibach Prokits, my ride height actually increased a tad, because my springs were really sagging bad.
Old Apr 7, 2007 | 01:41 PM
Ucantcme57's Avatar
Stock springs are usually sagging and lower than stock, but I hear that it takes a month or so for the lowered spings to get to proper ride height...
Old Apr 7, 2007 | 05:58 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Are you the only owner of the car? Maybe, a previous owner installed lowering springs.
Old Apr 7, 2007 | 10:15 PM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
nah.. im not.. but they were stock.. but i already said that they arent sitting in the spring perch right.. but can anyone tell me where to get the spring isolators???
Old Apr 8, 2007 | 12:31 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Found these on ebay:
http://cgi.ebay.com/ebaymotors/FRONT...QQcmdZViewItem
Also, any dealership, if your desperate enough, can get them as well
And the springs should be lined up as such http://pg.photos.yahoo.com/ph/tarami...ad.jpg&.src=ph
Old Apr 8, 2007 | 01:05 AM
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
oh.. i covered both holes.. thanks for the help.. and as far as those isolators on ebay ive seen those before, but i wasnt sure if there was anything better out there.. but i guess ill get those.. thanks for the help..
Old Apr 8, 2007 | 01:10 AM
krisb410's Avatar
Sorry for the attitude I had in the previous post, I've been out at the bars all night
I edited my previous post to fix it.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tmellott89
Aug 16, 2015 02:58 PM
Street Lethal
Aug 14, 2015 08:25 PM
