New Motor, New Mounts?
Old Jun 21, 2007 | 12:36 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Gonna be putting in a new 355 short block in the next week or two. Would it be wise to get new mounts? Would I need new mounts AND new inserts? Never done these before, someone point me in the right direction.
Old Jun 22, 2007 | 10:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: New Motor, New Mounts?
It'd be easiest to do it now.
Inserts should be all you need. Poly is the way I always go.
Old Jun 22, 2007 | 01:50 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
I would go and get some moroso solid mounts. I know you all are gonna have a stroke, but i run solid mounts and THE CAR WONT SHAKE ALL OVER like everybody is gonna tell ya. why waste HP and TQ letting that new motor twist in the bay???? PUT IT TO THE GROUND!!!!! Not to mention you'll never have to buy another motor mount again!!!!
I run a .284/.305 dur. .507/.525 lift shaft in an 11:1 383......mine dont "shake yer eyes out".....
Old Jun 22, 2007 | 02:56 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Poly inserts is the way to go. Using all metal motor mounts is good for performance, but does put more stress vibrations in the drive train, in particular to the transmisson. The poly is a trade off between metal and rubber mounts. I had this discussion with 2 different transmisson builders(automatic) and they both told me the same thing. It can put strain on the trans housing and tailshaft. They also recommend a poly mount versus a solid mount on the transmisson for the same reason. Badman
Old Jun 22, 2007 | 05:14 PM
Thanks guys, poly inserts it is.
Old Jun 22, 2007 | 06:20 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Go that way if ya want. After the third (thats 3) $60 poly drivers side i cut my losses and solved my issues for good. Your choice. Just telling you my experience.
Old Jun 22, 2007 | 07:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
wow, someone is getting rich off you. where in the world are you buying parts?
Old Jun 22, 2007 | 07:05 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Yes, now is the time to replace your motor mounts with poly mounts. New motor mounts will outlast you so I would not even think about solid, save that for the track if needed. When you use solid, the trans mount must also be solid or you will break your trans case, happened to me years ago.
Old Jun 22, 2007 | 07:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I run solid motor mounts and a poly trans mount, no broken trans cases, the only time in these cars you'd snap a bellhousing is if you're using a solid trans mount as well since these aren't tube chassis cars with no flex.
Old Jun 23, 2007 | 02:20 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used rubber mounts. So the shell comes with the insert, for $12 a side.
I also used a rubber tranny mount. I'd recommend the poly though, I think mine is a bit loose for my tastes. It's LOADS easier with the engine out
Old Jun 23, 2007 | 12:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
all the solid motor mounts ive seen require a poly trans mount. unless its a tube chassis car.
jhawkeye
May 25, 2022 06:33 PM
evan555222
Sep 20, 2016 02:51 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
