sway bar bushings
Old Aug 4, 2007 | 04:57 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
sway bar bushings
I picked up swaybars off of ebay from a 86 TA to go on my RS Camaro. They are a 36mm/23mm combo. Is it better to get hard rubber or poly for them. Where can I get poly, I looked around and couldn't find much. This is my DD so ride quality has some input as to which is better. Does poly on the sway bars really affect ride quality in the straight line? I do need endlinks also. None of the auto stores around here had the right size for the sway bars which surprised me. What are the sizes in inches also.
Old Aug 4, 2007 | 07:49 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: sway bar bushings
auto zone has energy suspension bushings and end links...the endlink set only cost me $15 and thats with poly bushings.
Old Aug 4, 2007 | 07:56 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Poly doesn't affected ride quality but really make a difference in how the sway bar reacts.Energy Suspension doesn't make a 36mm bushing as far as i know.Check with Lon at TDS(TGO sponsor) for the bushings,and backets if you need them also.He carries the end links also or you can purchase the ES from a local supplier as they are same front and rear(and bar size doesn't matter).
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I found the sizes I need. The sway bars are just a rare size I guess. Not many sites had anything for 36mm/23mm combinations. Ended up finding a bushing kit for the rear on summit and the bushings for the front from spohn. 36mm bushing are alot more expensive then other bushings.
Old Aug 4, 2007 | 08:27 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Sounds like it might be too late for you, but for anyone else looking,
the Guldstrand bushings are half price of Spohns and fit into stock
brackets.
http://www.guldstrand.com/scripts/pr...?idproduct=443
Old Aug 4, 2007 | 09:16 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
It is probably too late for me. Do they even list what size sway bar they fit?
Old Aug 4, 2007 | 09:32 PM
85MikeTPI's Avatar
In the pull-down menu, on the RHS in the "Ready to Order" box.
Old Aug 5, 2007 | 06:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You might double-check. The combo is usually hollow 36mm, solid 24.
JamesC
Old Aug 5, 2007 | 08:51 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
JamesC
I measured them with a micrometer and the rear came out to be about 23mm. I'll have to see when the bushings get here.
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
