rear springs
Old Nov 9, 2007 | 07:21 PM
texan_rebel's Avatar
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
rear springs
my car was originally a v-6 i was wondering if anyone knew if the rear springs on a v-6 are the same on a v-8, or will it be a good idea to get better springs? but i dont really want to drop the car.
Old Nov 10, 2007 | 08:28 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: rear springs
No, they're not the same. Get the moog 5665/5662 springs for the front and rear.
They're the stock replacements for V8 Z's and T/A's, I believe they're rated around 650 for the front, 150 for the rear.
edit: Look a couple a posts below........ Stock spring rates.
Though I think the 5664 and 5662's rates are swiched, and the 5665's I believe are a little stiffer than advertised.
Old Nov 10, 2007 | 11:59 AM
Car: 1989 RS camaro
Engine: 350Ci
Re: rear springs
i already got the v-8 springs for the front i just didnt know about the rear
Old Nov 10, 2007 | 12:12 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: rear springs
I found these springs seeing what yall thought
http://www.ecklerscamaro.com/product...dept%5Fid=1821
Old Nov 10, 2007 | 12:14 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: rear springs
Assuming you have a couple jack stands and a jack the rear springs are cake. 10 minute job tops. Take the nut off each shock and lower the rear while watching not to stretch the rubber brake line. You will have room to spare. You can unbolt the T-block for the brake lines from the rear end if you need more slack. The springs will just fall out. Set the new ones in and jack it back up and bolt the shocks back to the rear end and you're done.
[oops misunderstood the post...it seems a lot of people don't like those cargo coils. You can get true stock replacement springs that will keep the car at stock ride height.]
Old Nov 10, 2007 | 12:39 PM
Car: 1989 RS camaro
Engine: 350Ci
Re: rear springs
so you wouldnt suggest getting those rear springs? I was just trying to get siff spring to help it from bottoming out with i punch, but i dont have the engnie or drivetrain in yet so i dont know what it'll do, but i know i do need to uprgrade everything
Old Nov 12, 2007 | 02:02 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: rear springs
I used this set on my Camaro:
http://spohn.net/product.cfm?productid=1404
Here is a pic of the right height:
http://img168.imageshack.us/img168/5449/p1010005py6.jpg
http://img257.imageshack.us/img257/2386/p1010006wf1.jpg
http://img405.imageshack.us/img405/8642/p1010007gz2.jpg
Maybe you could email them and see about buying just the rears? Shocks can also have something to do with this.
Old Nov 21, 2007 | 09:56 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: rear springs
https://www.thirdgen.org/forums/susp...ring-info.html
That link my help.
The 5665 rears are 107 and the 6554 fronts are 707.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
