SFCs for an 89 Turbo T/A
Old Nov 23, 2007 | 08:10 PM
W72's Avatar
W72
Car: 89 GTA & 92 T/A covertible
Engine: 408LS-SC, 355 TPI
Transmission: 4L80e, 700r4
Axle/Gears: 12 bolt, 9 bolt
Being that the trans mount is different and the exhaust is a little different. Is there anyone here that has installed sub frame connectors on a TTA? If so what brand works and what brands don't.
Old Nov 24, 2007 | 03:11 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: SFCs for an 89 Turbo T/A
Just curious. Why would the trans mount be an issue?
JamesC
Old Nov 24, 2007 | 04:41 PM
W72's Avatar
W72
I wanted to use the TDS tubular style(Alston Racing) that connect to the ends of the sub frame and I don't think they'll fit. See pic
Attached Thumbnails SFCs for an 89 Turbo T/A-ttatrans.jpg
Old Nov 24, 2007 | 04:57 PM
JamesC's Avatar
Very interesting. I've never seen a cross-member like the one pictured. However, if you compare it with the ones in the following link, it "appears" to be situated in the same place on the frame. You might contact Lon at TDS for more info.
JamesC
Old Nov 24, 2007 | 05:14 PM
W72's Avatar
W72
I did...he hasn't replied
Old Nov 24, 2007 | 11:47 PM
Guest
Guest
Posts: n/a
They're not gonna fit. The alstons attach at the frame rails behind the factory crossmember and the tubing goes downward from there... so you wouldnt be able to put your tranny crossmember back in.
I'd go with the Spohn, UMI, or any other connector that installs near the rockers.
Old Nov 28, 2007 | 02:09 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
I have Spohn on my TTA, they fit great.
Old Nov 28, 2007 | 08:08 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
JamesC
Its a TTA specfic peice. TTA's came with 200-4R's which are a bit longer than a 700.
Old Nov 28, 2007 | 09:18 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
go with spohn.
On a side note, that is one of the cleanest under bodys I've ever seen on a thirdgen!
Old Nov 29, 2007 | 09:31 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Lon's (alstom) won't work. I asked Lon about them many years ago for my TTA.
Any Spohn style will work, you might like to double check the clearence at the flexbit on the down pipe. You should be fine as you have the stock system. With the THDP (3 inch) system you will have to cut it so the flex bit moves towards the center of the car about one inch or so. I got custom made SFC's similar to Spohn's on my TTA with a THDP and had to modify it slightly to get the clearens needed.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
cheesehomer
Dec 31, 2015 08:48 AM
2012sergen11
Oct 13, 2015 07:38 PM
bjpotter
Oct 4, 2015 07:48 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
