turn left, BANG?
Old Apr 5, 2008 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
turn left, BANG?
just took the car out for a spin, the second time this year. I got a bit aggressive with some turns and noticed that when i take a hard left turn, i get a loud, pretty solid sounding BANG from what sounds like the left rear .
I got under the car and cant find anything that appears to be hitting, nothing is busted, no impact/scuff marks on any suspension component. the sway bar is a little close to the shock, but there are no marks or evidence of them hitting.
I did notice that i seem to have some rubbage on the inside fender well, only on the left side. With the car sitting on the ground i have over 1/2" of clearance from the tire to the well. the tires have little sidewall, 335/30/18, so i cant imagine that they are bulging enough to touch? the panhard bar is perfectly level. I'm little confused. It doesn't sound like a rub, and the scuff marks are not very heavy so there is no way they were causing the sound.
this couldn't possibly be coming from the axle could it? maybe its ready to let loose?
Old Apr 5, 2008 | 06:34 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Re: turn left, BANG?
Check and make sure your pan hard bar is there and tight.
Old Apr 5, 2008 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its there and in fine working order
Old Apr 5, 2008 | 10:33 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Often times when I have the wheel turned to full lock to the left or right, there will be a loud poping sound coming from somewhere on the car. Can't remember where since I just got it out of storage today and have yet to hear it, but I do remember a lot of other people having the same problem. I think one person even replaced every part of their suspension and still had the problem. From what I remember, no one came to a conclusion about why it happens.
Old Apr 5, 2008 | 10:59 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Take a real close look at the front torque arm bushing, it may have split and the hard cornering is letting it ride too high in the bushing, when you staightin up it SNAPs back down.
Old Apr 6, 2008 | 11:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
well its not the torque arm bushing, i have a pretty new UMI crossmember mounted arm and the bushings are fine. the marks in the wheel well are not rubbing, just marks in the new undercoating from when i put the wheel on.
Im really starting to think its the rear. When i get some more nice weather, i'll have to flog it a bit and see if i can make the noise worse or break something... then i will now for sure .
I just find it weird that i only happens turing left?
Old Apr 6, 2008 | 02:55 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
What kind of ends do you have on the PHR? I know people who have 315's on their fourth gen need a rod/rod to stop the rubbing, but I'm not sure how much clearance they have.
Old Apr 6, 2008 | 03:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the panhard has 2 rod ends, they are IN the wheel, so no issues there
Old Apr 6, 2008 | 06:43 PM
Maybe excessive wheel hop made more noticable by a bad shock.
Old Apr 6, 2008 | 09:03 PM
Car: 1987 IROC-Z
Transmission: TH350
There was another thread where someone ruled out the rear because the car still made that poping noise after they rebuilt the rear.
Does it only do it when you have the wheel turned full lock or just whenever you turned the wheel?
Old Apr 7, 2008 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its only when i have the wheel turned to full lock or close to full lock. Not when driving slow, like in a parking lot, only at speed.
Its a single loud metallic bang, not wheel hop.
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bdads
Aug 24, 2015 06:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
