What exactly are they selling?
Old Jun 1, 2008 | 11:22 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I just bought UMI rear package and was starting the install and realized I don't have any grease. Since I don't feel like waiting a a week for the poly grease and rod end lubricant to get here, does anyone know if I can just go to Autozone or some place to get the stuff? What is the name of it? Could I just use white lithium grease?
Old Jun 2, 2008 | 05:56 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: What exactly are they selling?
most any auto parts place would have what you need .
Old Jun 2, 2008 | 11:15 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
It's not white lithium grease, it's like a synthetic silicone based grease. Try the auto parts store.
Old Jun 2, 2008 | 05:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can use the lithium grease, its what ive always used. You only get a little packet of the silicon grease and you still have to pump the bushing full after install. Just lube the outside up good.
Old Jun 3, 2008 | 03:43 PM
Car: 1987 IROC-Z
Transmission: TH350
Ok, so lithium is good for the poly bushings... but what do I use for the rod ends? Can I just smear some lithium grease on there and turn it around and wipe the excess off?
A fast response is good because I'm installing UMI's rear package at the moment.
Old Jun 3, 2008 | 04:07 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
You could have avoided this dilema by ordering the proper grease when you placed your order
I have not found the proper grease at any parts stores around me. You do not want a petroleum based greased though.
Super Lube is a brand named synthetic lubricant that comes in both a canaster and aerosol forms. Both are reccomended by UMI and Energy Suspensions.
Old Jun 3, 2008 | 05:55 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
autozone sells little packets of energy suspension formula 5 prelube. it's a dielectric based synthetic grease that is for poly pushings. i've heard the petroleum based greases will ruin the bushing over time. i used the ES stuff initially but then bought a cartridge of the similar stuff from spohn.
Old Jun 3, 2008 | 07:16 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
For rod ends you can use run of the mill suspension/chassis grease. Any parts store is GUARANTEED to have it. As for the poly bushings, white lithium is not okay. You need a synthetic grease. If you can't find it locally you should order a tube of it from the place you bought your suspension parts. That's just what ya gotta do, we've all been there. Trust me, my car has poly bushings bumper to bumper.
Old Jun 3, 2008 | 07:25 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Super Lube is the stuff i use. Good stuff, big cartridge too fits a standard size grease gun. http://www.spohn.net/?action=product&pid=1006
Old Jun 3, 2008 | 08:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
aren't the spherical ends self lubricating? just hit them with the spray lube once a month or so and your good
Old Jun 3, 2008 | 10:06 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
ooo, I thought he was talking about tie rod ends... yeah I'm not sure about spherical rod ends I've never used em.
Old Jun 4, 2008 | 11:46 PM
Car: 1987 IROC-Z
Transmission: TH350
I was asking about the bushings on the LCA's and panhard bar I just installed (they are rod/poly).
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Stangski09
Nov 14, 2015 01:27 PM
buckshot63
Sep 10, 2015 09:15 AM
scottmoyer
Sep 7, 2015 07:06 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
