best shocks to go with BMR coil over kit + tubular A arms
Car: bandit II Firebird
Engine: 3.1
Transmission: auto
so yeah i kinda said it all in the title, and its for a street car
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: best shocks to go with BMR coil over kit + tubular A arms
i assume the BMR coil-overs are the same idea as Spohns?
the best over the counter? koni yellow for performance, bilstein for ride comfort. $$$$
Guest
Posts: n/a
Nope, Best over the counter are these badboys. Full aluminum and double adjustable. Chassisworks Varistrut.
How come every time I want to attach a file it comes up invalid? this site never used to have this problem.
Here's the link. You'll have to chase downt he Varistrut on there site because I can not directly link the product page showing it.
http://www.varishock.com/
Guest
Posts: n/a
http://www.varishock.com/DataSheets/...952_DS_WEB.pdf
You have to go to the advanced post/edit. Its been like that a while for links.
Car: 86 Trans Am
he asked for the "best strut" for BMR's coil-overs, not the best coil-over setup available for the car, unless you can buy just the struts from varishock?
Engine: 3.1
Transmission: auto
ok dumb question is it coil over strut not coil over shock then why deos this one say will no work with bilsteins http://www.hawksthirdgenparts.com/in...OD&ProdID=1673
Car: 86 Trans Am
Guest
Posts: n/a
I was aware of his question also, and even thought YOU are fully aware of this product, he was not and you did not suggest it. It is a far better alternative to go with buy just getting the lower thread adjuster and using an actual designed "coilover threaded strut" than using one of those crappy slip over theaded sleeve adjsters onto a comventional strut.
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
