Installing Hotchkis RLCAs and Panhard
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Hey guys I just bought a pair of Hotckhis RLCAs and Panhard rod locally for super cheap and I'm wanting to install them a little later today. I got a question though. I looked up the instructions and they say I would have to drop the springs out of the way. Now, is there a way to avoid that step altogether? Can I take the tension off of the LCA bolts by putting a jack on the diff and then rest a jackstand underneath one side so the spring wont shoot out?
Axle/Gears: '01 3.42 10 bolt
Re: Installing Hotchkis RLCAs and Panhard
i don't remember taking the springs out when i did mine. maybe they are concerned about them falling out unexpectedly if you take tension off of them. i put the rear end on jackstands and installed mine. didn't have a problem with the springs.
Car: 91 Camaro RS
Engine: 305 TBI *355 Coming Soon*
Transmission: 700R4 *T56 Coming Soon*
Axle/Gears: 323
Sam all ya gotta do is jack up the diff, throw some jack stands under the rear and unbolt everything... Its really not that bad!
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Car: 91 Camaro RS
Axle/Gears: 323
Yeah just make sure you jack up the rear tight so that they are secure under the car and do the LCA's one and a time and do the panhard bar last!
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Will do, Thanks man! Hopefully I wont break any bolts. I soaked them down overnight as a precaution.
Car: 91 Camaro RS
Axle/Gears: 323
Nice to see that you didn't break any bolts and I'm assuming no fingers either since there is no mention of tragic mishaps LOL
I have to ask though, what is with the multicolor exhaust??? LOL
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
The previous owner was Puerto Rican, and he sprayed it with the colors of the PR flag. Yeah, I'm swapping the muffler out.
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
