Installation Pictures of Tunnel Mounted Torque arms
Hello Everyone,
Since we have had a lot of request from customers we finally put some installation pictures up on the site of our tunnel mounted torque arms and I would like to share. These set-ups are designed to fit the 700R4, T5, TH350 and TH400 transmission and work excellent for transmission swaps. They include a new transmission crossmember and a adjustable torque arm and they can be purchased with or with out a NHRA legal drive shaft loop. If anyone has any questions please ask.
Enjoy the pictures!
Installed with no drive shaft loop-
With built in drive shaft loop
Enjoy the pictures!
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Installation Pictures of Tunnel Mounted Torque arms
After looking at those pictures and how nice that crossmember and torque arm look, I wish I would have upgraded... especially since I had all that out. Bad thinking on my part.
Mike
PS - Love the sig!
Edit: Shouldn't there be washers where the tranny crossmember gets bolted to the body? I just looks like those bolt heads are barely big enough to cover the holes. The stock piece has washers there.
Mike
PS - Love the sig!
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
yea ryan, where are the washers? they come with the install kit with the torque arm you know. they came with mine.
-edit look at the pics, the washers are there, they are just small diameter, SAE type
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Damn, one week after I bought the normal th350 crossmember. I wasn't sure how the other one installed so it scared me a little since I am new at this. It looks pretty st8 forward. Stupid newb me, I thought tunnel mount meant it some how mounted to the trans tunnel area of the body which seemed like a lot of fab work.
Insert expletives here "@@@@@@@@@@@!!!!!!"
Car: '82 Z28
Not exactly what I would call a tunnel mount, more like crossmember mounted. Looks like a nice piece though, better than the low hanging Spohn crossmember I have now.
That looks mint Ryan. I'll be getting one of these over the winter months for my IROC. Once the time comes I'm sure I'll have a few orders for your products done, my buddy with his '91 RS is going to need lots of stuff.
Thanks everyone
They are priced from $379 to $439 depending on the model. Here is a link for all the information- http://www.umiperformance.com/produc...ategory_id=114
1 Post
Car: 1987 IROC-Z
Transmission: TH350
What makes the SAE washers so great? The first time I have ever seen them was when I installed the Hotpart/J&M strut mounts.
Car: 1971 Camaro
Engine: 427
Any pics of the TH400 cross member? I am looking for one and was going to go with the Spohn, but am concerned about the ground clearence, exhaust clearnce.
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
I wonder if they'll make a rod-ended version eventually? And also since the ground clearance isn't as bad, I wonder if long tubes and mufflex y-pipe would clear it.
Here is the TH400 transmission crossmember and torque arm below with crossmember below.. the installation is indentical to the pictures posted above.
TH400 Transmission Crossmember Only
Crossmember Mounted Torque Arm with No Loop
Crossmember Mounted Torque Arm with Loop
So ryan, i know i pm'ed you on how to mod your 700r4 crossmember for a tko500/600, any plans on offering that one too?
Interesting. Two questions: 1) Can I assume that the cross member is a direct bolt-in for those cars originally equipped with a secondary cross member? 2) There are three bolts per side in the pics above. There are only two on the OE. Is the forward bolt hole threaded from the factory?
JamesC
JamesC
JamesC
JamesC
the extra 2 holes are not threaded from the factory, but the inserts are there and ready to be threaded, i think its 16mm1.5?
I believe those holes were used in the early cars with the 200r4?
Car: 1982 Z28
Yeah I already have it on the car. It is a top notch piece and I am very happy with it as I expect to be with the suspension stuff I have ordered through the group buy.
I thank you for all your support through this site by the way. It helps answer questions that I would have had to call about.
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
is or will there be one for a t56 swap?
Car: 1987 Firebird
Engine: 355
When you thread the third hole, do not torque the hell out of the bolt you put in there. I dont know why, but the metal seems to be very very soft. It will hold its own on vertical forces, but cant take too much torquing.
ALSO: DITTO on the T56 swap x-member. I was hoping you guys had one, but i either had to buy from Spohn or Skulte. I didnt like either, so it came down to price......
Im not happy with my spohn x-member. Its a quality peice, (looks like good welds and craftsmanship) but its way too low.... I cant go over speedbumps because of it.
If you make one, PLEASE make sure it stays ABOVE the lowest factory item on the car. ieL either the sub-frame rails in front, or a factory cat. You guys are usually pretty good about that.
If you had one, i would have bought one.
+1 for T56 swap and TKO series trans x-members.
Ryan,
Any comments on the following:
Interesting. Two questions: 1) Can I assume that the cross member is a direct bolt-in for those cars originally equipped with a secondary cross member? 2) There are three bolts per side in the pics above. There are only two on the OE [the OE bolts are M10 x 1.5 x 32 torqued to 35 pounds]. Is the forward bolt hole threaded from the factory?
JamesC
JamesC
JamesC
JamesC
I am not sure what you mean by vehicles with a secondary crossmember? Please explain and I will be glad to help.
I am unsure of the years but I think its 84 - 92 vehicles had the (3) holes for the crossmember although the factory crossmember still only used (2) holes... the 82 and 83 models might have only had (2) holes? Don't hold me too that. All vehicles we have here have (3) holes in the frame from the factory so no drilling or trapping is required, we just took advantage of the 3rd hole for additional support.
Hope that helps!
Ryan
https://www.thirdgen.org/forums/atta...ber-mounts.jpg
JamesC
Many cars were equipped with the secondary cross member as seen in the following pic:
JamesC
JamesC
thanks!
Ryan
Car: 1971 Camaro
Engine: 427
I am ready to buy a th400 set up.
Can you tell me if I will run into clearence issues with long tube headers and your crossmember?
most likely, LT's and crossmember torque arm, no matter who makes them, dont play well together. You can probably get creative, use oval tubing, and run the pipes under the subframe just before the crossmember, but ground clearance will still suffer.
Do you have any pictures of your exhaust?
Thanks,
Ryan
Car: 1971 Camaro
Engine: 427
I do not have any exhaust right now.
The HEaders are ED Quay 2.25" primary 3.5" collector.
I plan to just run pipes back with bullet mufflers and turn downs.
The car is a drag car.
The best thing to do there is build the exhaust around the torque arm... that is what we do in a case like. Its the only way to guarantee the correct fitment
Car: 1984 Z28
Engine: L69
My crossmember and torque arm were just delivered yesterday. They are beautifully made and I can't wait to install them! One thing that's not mentioned in the installation instructions, should the torque arm be attached to the top or middle hole of the link connecting it to the crossmember? Would there be an handling/traction difference using one rather than the other?
Thanks,
Mike
Thanks,
Mike
Ryan,
I was/am interested in this piece (and had added it to my shopping cart); however, I am a bit troubled by the following link. Would you care to comment?
https://www.thirdgen.org/forums/susp...orque-arm.html
JamesC
JamesC
Ryan,
JamesC
JamesC
the issue with rubbing on the fuel line bracket is with the bolt head that secures it on top. the bolt holding my fuel line is longer than it needs to be probably 5/8 overall length and when the bolt is fully tighted the bottom of the bolt hits the tunnel and instead of pulling the bracket towards the tunnel it pushes it out, as it bottoms out it pushes it towrds the torque arm. i was lazy and just ground the head down some. a slightly shorter bolt and some light massaging would have been the proper fix but some cars may have slightly longer or shorter bolts so that was not that big of deal.
although i am having a terrible driveshaft vibration problem pinion angle has been set from -8 through +5 degrees.
when i removed the original crossmember , before install, i had the trans supported on the pan, and as i installed the new crossmember and i tightened up the bolts it moved the trans up another 1/2 inch or so. i am using a energysupsension bushing. it worked on the stock crossmember.
this crossmembere does hang a bit low. probably an inch or so below sea level it scrapes on steep driveways and excessively tall speed bumps. on the outside tabs, not the weaker center area wich is aboutr 1/4 above theese tabs/ears. i do worry about hitting any bumps or dips at speed i think it might due severe damage.
the rear is centered i spent propaly 4-5 hours total meassuring and playing with it untill it looked, measured, and performed perfect probably within 1/32" -1/16" centered. i'm very picky about things not being perfect.
but on a good note this torque arm makes a hudge diffference, and is very heavy duty!! i still haven't got mine dialed in but no matter where it's set the traction is way better than stock, just not having the pumpkin twisting up and down makes the car way more preddictable and the throttle is more responsive to the tires. i'm not sure if its in my head or not but it feels like the chasis flexes a little less when i'm throwing it around, maybe the stiffer crossmember helps???
after i get rid of the vivbration and get it dialed in i think i'll be very happy with it
i sent an email to umi today to ask about the vibration problem, i will post results
almost forgot i have a 4th gen aluminum DS and the front yoke area is located further down the the drivshaft, than stock. and in my case putting part of the yoke area inside of the DS saftey loop, the stock DS is shown above in the install pics and it fits in there great, the 4th gen fits but with about 1/8" clearence around yoke/pivot area and i was worried about the corners catching inside the loop during driveshaft vertical movent while to the rear is moving up and down, i eneded up with the grinder once again shaved 3/16 of an inch off the DS safety lope inside edge, so just a little heads up for you 4th gen aluminum DS people, i'll try to get a pic tomorrow
Ryan,
JamesC
JamesC
Fuels lines can be in different locations since they have most likely been changed at one time... we can't control this. Hitting the tunnel in the rear is common, the torque arm has to sit to the drivers side... every brand does this Spohn, BMR ect... there all the same. A little tapping on the tunnel with a hammer will take care of this. As for the front, if they have a T5 the mount on the transmission needs ground off... this isn't in the instructions yet. Other transmissions do not need this.
I don't think you will have any issues. Thank you,
Ryan
I had the same issue, went back to stock type tranny mount, all is fine now. Just something about the ES mounts. I tried ES and Prothane brands, but the stock rubber one is the only one I could get to work with no vibrations.
#42
for the record i'm running the prokit in the rear, with no isolaters so i'm probaly a bit lower than most, that extra 1/2 inch in height would probaly be enough to keep the TA from hitting in the tunnel. dont' be confused the TA wasn't hitting the fuel lines jus tthe bolt head, realy not a big deal just make sure your clear before you start the abuse.
i swapped the poly trans mount in a couple of years back, and i was thinking about it when i installed the new mount i think it was a bit taller than the factory rubber mount. it's hard to say it was broken in 2 when i removed it. so i won't be using a rubber mount again
i think i'll pull off the new crossmember install the original with the poly mount and measure the difference the new crossmember makes, than maybe trim down the mount accordingly.
UMi said to use the factory rubber mount, but i was reading another post, forget if it was about umi or spohn, Tunnel TA, but they said they had the same problems with vibration, with the the factory mount and were told to use the energy suspension bushing and ended up triming down the ES bushing to success.
https://www.thirdgen.org/forums/afte...ight=spohn+buy thats the post, ended up trimming down the bushing
Last edited by 1988-305-tbi; 12-02-2008 at 07:43 PM. Reason: Automerged Doublepost
#43
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
Old thread but I am just wondering, I have the torque arm with the tunnel mount setup. And there is not anywhere close to enough room for the linkage to mount properly because the old tail shaft mount is directly in the way. Is the transmission mount suppose to go in the center slot of the cross member or is there something else I have messed up??
#44
yes the trans mount goes in the canter hole, some poly mounts give you the option of using 2 bolts through the crossmember for added strength, hence the extra slots in the crossmember.
remove the old torque arm bracket form the tail shaft if its in the way.
#46
Yeah the whole bracket is gone. The spot where the lower bolt of the bracket mounts is in the way. So it appears the only way to make it work is to cut off the nub-hole that sticks out in the way of the linkage, unless there is a way to adjust the linkage so it does not run into the tail shaft nub.
#47
Also this is on a rebuilt 700r4 so Im not sure if its possible that tailshaft got swapped.
#48
i had the same issue with my TA after removing the mount, the raised part of the TA where the mount used to be was rubbing, i took a cut off wheel to it and took off 1/2" and no more problems
#49
Figured it out, like you said I had to cut the mount off that was overlapping the travel of the linkage. It would have been nice if that was mentioned in the directions. But other than that it fit right in and hooked right up. So far i am pleased with how well it works and I have no noticeable vibrations.
Here is a picture of the overlap.
#50
glad to see i'm not the only one that had this problem, mine looked exactly the same as the picture
