Where the HELL is that noise comming from?
Old Nov 5, 2008 | 03:42 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
ok sometimes when im driving over bumps there is this... "knocking" sound/felling under me. i drive with the door open to find it and still cant. i hear it but cant tell from where. i noticed my pan bar busing was out. replaced it. then sway bar bolt was too. tightened it. still cant find it. it ALMOST sounds like a rattling caliper but its below me? somebody help PLEASE!
Old Nov 5, 2008 | 03:48 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Where the HELL is that noise comming from?
Check your torque arm and tranny mount bushings.
Old Nov 5, 2008 | 11:02 PM
Car: 02wrx/88 rs
i did. the tranny mount is good. and t arm. what else?
Old Nov 5, 2008 | 11:53 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Does it do it when you turn or over speedbumps up front? I had a bad upper strut mount that clanked around a bit under a mid-speed hard turn.
Old Nov 7, 2008 | 07:02 AM
Tranquil's Avatar
Not to state an obvious possible problem...
But is there any chance it could be your exhaust rattling? That's below you, and even if the rattle is in the back the sound vibrations would move up the entire pipe.
Old Nov 8, 2008 | 12:23 AM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
Phucking gremilins i just drive with the music on im tired of looking for loose **** lol
Old Nov 8, 2008 | 12:42 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
check your u-joints too, they will pop when they are worn.
Old Nov 8, 2008 | 01:31 PM
larryjoe's Avatar
Car: 88 formula
Engine: 350 tpi
Transmission: 700
Axle/Gears: 3:23
Mine did the same thing on bumps, I had to tighten the lower control arm on the front it wasnt loose but i had to tighten a little more and it stopped, seemedlike it always did it, it front of alot of people lol.
Old Nov 11, 2008 | 09:03 AM
Car: 02wrx/88 rs
well the tranny was just replaced. i think they would notice the u joints? not the ex. i checked that too. control arms? maybe........ any more advice?
Old Nov 11, 2008 | 01:22 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Dude, I had that same issue. Does it have a bit of a rattling sound? I had that happen so I took a long look. Ended up being my sway bar end link bushings. The stock ones were so degraded that a couple of them were almost non-existant. Swapped out some poly's and the noises are gone. You can easily take a look at them without having to jack up your car. Takes two minutes to inspect.
Old Nov 12, 2008 | 12:44 AM
Car: 02wrx/88 rs
ok trying to describe this.... i guess.... take a wrench. and tap it on your floor board. that sound it makes. its like that only faster. i just replaced the sway bar linkage. that helped some of "a" noise but not "the" noise. same deal with the shock bolt.
im starting to think MAYBE, but doubt it, it the shock mount? its the only other thing it could be? more info on this?
Old Nov 12, 2008 | 05:32 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
On the same note.. Mine makes this horrible cracking noise when I do a very hard right, or left turn, I was leaning toward a motor mount, but a broken spring seems in order because of the right side sitting lower to the ground..
Old Nov 12, 2008 | 06:12 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check the easy things, like a loose dust shield on the rear brakes will give you that sound (nice rattle over bumps).
Old Nov 13, 2008 | 07:56 PM
86transam383's Avatar
Car: 1986 Trans am
Engine: 383ci
Axle/Gears: 2.77/3.45 ready to go in
is it a clacking or a clunking sound? o.0
Old Nov 13, 2008 | 08:29 PM
Car: 02wrx/88 rs
lol if i had to pick i would say clunk. lol they are all the same lol
god i got my ex leak fixed and it sucks cus i can hear more noises now!!!
but now two new ones. with the other. knocking poping noises on the front susp. i need to check the brakes and stuff. and a dam phucking sweek from ex hangers?
theshackle
Sep 17, 2020 08:26 AM
mhatfield 14
Oct 24, 2015 07:48 AM
B_Dubya
Aug 26, 2015 05:09 PM
86IROC112
Aug 20, 2015 12:18 PM
BlackBoulder
Aug 11, 2015 11:15 PM
