Swapping on C5 brakes, toasted my tie rod/LBJ?
Old Mar 11, 2009 | 01:44 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
Well, it appears that I have messed up the boot on my outer tie-rod end and LBJ. Plus, LBJ still hasn't unseated from the spindle, any suggestions? The BFH approach hasn't yielded any results. Anyway, the boots are torn, are the joints now considered junk and need to be replaced? The car seemed to drive fine so I was hoping not to have to do this, including dropping the LCA. If I do that, I might as well do the springs and LCA bushings, but there really is no money left in the budget right now.
Jeff
Old Mar 11, 2009 | 04:12 PM
Car: 1992 Z/28
Re: Swapping on C5 brakes, toasted my tie rod/LBJ?
Also, how would i know if my springs were worn/sagging and need to be replaced? I know my struts are worn, and are getting replaced...
Old Mar 11, 2009 | 04:57 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Why not just try and find a set of boots?
Old Mar 11, 2009 | 07:23 PM
1988-305-tbi's Avatar
Old Mar 11, 2009 | 07:26 PM
i would only replace the springs if you are planing on putting in higher spring rates for handling, if you are happy with the way it rides/handles, you'r springs are good.
Old Mar 11, 2009 | 08:45 PM
Car: 1992 Z/28
Originally Posted by 1988-305-tbi
I considered that, but wasn't sure if that was acceptable since it seems one of the boots is still solid (not cracked), it just separated from the joint? I didn't think if I pushed it back on it would stay... I guess that was my question, whether replacing the boot only was acceptable. Guess, based on the responses, it is! I'll see what i can source for them.
Guess I'll leave the springs and LCA's as is for right now too.
Jeff
Old Mar 12, 2009 | 06:22 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Check out what Spohn has to offer...
Tie Rod
Lower Ball Joint
Old Mar 13, 2009 | 04:36 PM
camaro430sut's Avatar
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I have the energy suspension boots on my ball joints after I ripped the old ones. Havent had a problem with them. Jeffery, where in CT are ya from?
92projectcamaro
Dec 8, 2015 12:25 AM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
92projectcamaro
Sep 29, 2015 07:07 PM
