impala ss wheels
Old Mar 23, 2009 | 10:38 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
impala ss wheels
ive been considering these wheels for a while.
not sure how it would look, but ive seen these wheels in person, and they look pretty tough
any ideas?
i would need adapters because they are 5 on 5 bolt pattern, but with 8.5" wide wheels, it would be ok.
wheels:
http://www.keymotors.net/sswheel.JPG
Old Mar 31, 2009 | 11:44 PM
Jim the Nomad's Avatar
Car: 2004 GTO
Engine: 5.7
Re: impala ss wheels
There was a guy around UCF that had impala ss wheels on his black RS.
They look almost like they could have come from the factory that way... you know, except for the impala logo on the center caps.
Old Apr 1, 2009 | 12:51 AM
IROCFAST's Avatar
A while back someone was making those in a 5x4.75 pattern. Check around and see if you can still get those.
Old Apr 1, 2009 | 05:29 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
you wouldnt happen to know who would you?
i wish they were 17" but you cant have it all
im not a fan of some of the flashy wheels people put on their cars these days.
i wish someone made an affordable 9" wide, 16 or 17" wheel in our backspacing
Old Apr 1, 2009 | 05:38 PM
Stephen's Avatar
Car: 87 GTA
Lots are out there, to bad most f them require the use of those adapters, which only adds to the cost.
I found me a set of the 17" x 9", older, no longer made, ROH Snypers.....Direct fit, no adapters needed.
Look around & you can sometimes find those for sale.
Old Apr 2, 2009 | 08:04 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
94-96 Impala SS wheels are 17x8.5 with 5in backspace
Old Apr 2, 2009 | 09:21 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Skulte sales the 3rd gen offset ROHs ZS wheels, $247 per wheel for 17x9.5 and $206 for 17x8.5s. Personally, I prefer the Snypers lol.
Old Apr 2, 2009 | 09:35 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
yeah, me too.
i know, which is why i want them
i dont think it would be easy to do though.
i would have to either re-drill my axles, or get a super expensive adapter.
Old Apr 3, 2009 | 12:16 AM
IROCFAST's Avatar
Or you could get the wheels redrilled...the center cap would cover it.
Old Apr 3, 2009 | 12:31 AM
Stephen's Avatar
Car: 87 GTA
Much safer to redrill the rotors/drums, put new wheels studs in the new holes, than drill the wheels themselves.
Old Apr 3, 2009 | 08:44 AM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
yeah, me too.
and why i wanted them for my 9C1
Old Apr 3, 2009 | 04:43 PM
IROCFAST's Avatar
Discount Tire and Americas Tire and most other large tire/wheel disributors do it all the time with great success.
Old Apr 3, 2009 | 04:54 PM
Stephen's Avatar
Car: 87 GTA
Doesn't mean that new lugs aren't still safer. Not all wheels have the extra material where the new holes are located, to retain the strength.
Besides....Why have the 5 extra (old ) holes that are no longer needed (nor used anymore)?
Old Apr 3, 2009 | 05:39 PM
IROCFAST's Avatar
So putting extra holes in the drums and rotors is safer??? I would have to agree to disagree.
Old Apr 3, 2009 | 05:48 PM
Stephen's Avatar
Car: 87 GTA
When done CORRECTLY, the old holes are welded shut & the new one drilled.
Never seen someone weld up old holes in an aluminum wheel. Or even a steel wheel, for that matter.
Old Apr 3, 2009 | 06:23 PM
IROCFAST's Avatar
So put extra heat in the rotors or drums, take the chance of warping them, then send them to be milled so the wheel will set flat...like I said before, agree to disagree. How many cars have you done this to?
Old Apr 3, 2009 | 06:33 PM
Stephen's Avatar
Car: 87 GTA
Never needed to. I buy wheels that fit right the first time, so I don't hafta buy the wheels, then pay more to make them fit. That includes spacers or adapters.
Old Apr 3, 2009 | 09:16 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
im going to agree with stephen here.
fox body mustangs came with re drilled axles from the factory.
ford decided that it would be cheaper and fit the needs of the (stock) car to loose one lug bolt, so they re drilled them for 4 lugs, then welded the old holes shut.
its a common mod to then re drill the axles for 5 lugs...
its actually a very common thing.
i wouldnt trust re drilled wheels.
if you look, there is a lot of metal surrounding the lug holes
in the spaces between, there is a big hollowed out space on the back of the wheel.
not safe IMO.
Old Apr 3, 2009 | 09:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Oh, now you gotta go dissin people with spacers lol
Old Apr 3, 2009 | 09:55 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
well its not my cup of tea, lets just say.
if you do it correctly, then its fine i guess, but those spacers are big bucks
Old May 4, 2009 | 09:00 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
If you're still looking at the Impala wheels, I've got a set of 5x4.75" hub to 5.5" wheel adapters that were machined machined for the wrong vehicle, and would sell for half price - PM or email me if you're interested. They're a bit on the thicker side for this application - 1 pair is 2" and the other pair is 2.25", but would give it an aggressive stance. Not sure of the Impala offset, or if the 8.5" wide wheels would be fully tucked in the fenders, so you would have to measure that (or back calculate it).
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
IROCZ1989
Sep 4, 2015 11:54 AM
