the heck am I supposed to do about a spare tire!
Old May 4, 2009 | 12:29 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
my daily driven street car has 13" C5 front brakes and 12" LS1 rear brakes. Stock spare tire not even close to fitting over either of these. Even the 1LE/space saver inflate-a-spare won't fit over the C5's. Is there a company that makes custom spares or something? Does anybody know if a 4th gen spare will fit over the C5's?
I don't suppose the C5 vettes even had spare tires...
Old May 4, 2009 | 12:34 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: the heck am I supposed to do about a spare tire!
Just get AAA for flat tires.
Old May 4, 2009 | 12:37 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Only thing i can think of is getting a 4th gen spare to keep it cheap, and if you have a problem, you can swap out a back wheel with the donut, and move that wheel to the flat in the front. Only problem i can think of is if you have different back spacing front to back, that that spacing may cause problems having that wheel in the front. Best thing would be AAA, lol.
Old May 4, 2009 | 12:38 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Well I already have AAA 100 mile tow so good point
Old May 4, 2009 | 12:55 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ive been thinking about this recently. I have AAA also, but still want the option of changing my own tire if I need it.
Im running LS1 brakes front and rear. I plan to get a 4th gen spare, which SHOULD fit over the brakes.
However...Im running a posi...so if I get a rear flat, Ill need to put a tire from the front on the rear, and put the donut on the front. This isnt usually the accepted place for a donut, but it'll get me out of where ever I am without hurting my diff. Just gotta milk her home or to a shop.
I wish the inflatable spare that came with my car still worked. The sidewalls are trashed and it wont inflate. Oh...and I wish it fit over the brakes. haha.
J.
Old May 4, 2009 | 02:13 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Look for a GTO spare. I've seen people use them as wheels for their skinnies, and I believe they are a 17" wheel.
Old May 4, 2009 | 02:17 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
he can only do that is they are the same diameter. not good to have two diameter tires on rear. boo bad.
Old May 4, 2009 | 02:20 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
It doesn't hurt if they are on the front (as the wheels are completely independent). It will mess up a positraction rear end, though. At least I think that's right.
Old May 4, 2009 | 02:29 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
http://www.tirerack.com/accessories/detail.jsp?ID=38
This is very similar to what came with my G8 GT.
Many car comapnies are starting to use these insead of the spare/jack setups...
Old May 4, 2009 | 02:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
How you like the G8? I can't wait til I graduate college next spring. I'm wanting to get this years GXP with the hopes it'll be cheaper lol
Old May 4, 2009 | 10:54 PM
Rayvan's Avatar
Engine: LB9 225HP
Axle/Gears: 3:45BW
It's a keeper, for sure...
Wife likes the quieness compared to the Firebird. It would still kick the Firebirds *** in a drag-race, but I think the 'bird corners just a little bit flatter. When the road gets rough though, the G8 holds like it's on rails where the Firebird starts to step out, and is a handfull to keep in it's lane.
That Zeta chassis is top-notch. Not "just for a large sedan," it's handling is top-notch for any car, like it's carved out of granite. Driving the car belies it's size. It "drives small" for lack of a better description.
Next week it will be a year old and it hasn't had a single issue....
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
