stupid a arm question
Old Apr 20, 2009 | 08:26 PM
Twin_Turbo's Avatar
Stupid question, are our a arms shared with other models? They sure look like the 2nd gen ones but I'm not sure if they are the same, almost looks like the 2nd gen ones have the bushings a little further apart but I can't confirm.
Does anyone have dimensions or an old GM part #? I have a lead on some arms but the seller doesn't know what they are from. Any help would be appreciated.
Old Apr 21, 2009 | 06:18 AM
Twin_Turbo's Avatar
Re: stupid a arm question
Really...no one?
Old Apr 21, 2009 | 06:41 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
pa racing sells 2nd gen tubular a arms in sets (upper and lower) for around 800 dollars.
im not an expert, but it seems to me that if it requires upper and lower, and ours only have lower, then they must be different, but i dont know for sure.
contact them and ask...
im sure they would have an answer
Old Apr 21, 2009 | 06:44 AM
Twin_Turbo's Avatar
2nd gens use double a arms, ours uses a McPherson strut but the old style spring is still retained, the holes are even there for the shock in the center of the spring, the shock is just not there because of the strut (GM cheaping out)
Old Apr 21, 2009 | 07:01 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
yeah, i dont know.
i wasnt aware that shocks and double arms would be more expensive than single arm/strut.
i figured the reason was for handling...
although i guess double a arms can be tuned much more easily by reloacating the upper arm and installing taller spindles.
we are pretty much stuck with our geometry
Old Apr 21, 2009 | 07:57 AM
Twin_Turbo's Avatar
The arm is set up for a spring and shock, so it must be someething GM either had lying around or is used in a car with no McPherson strut. The McPherson system is a compromise that offers more room in the engine bay but the suspension geometry is not as good as a properly set up double a arm system.
Old Apr 21, 2009 | 09:41 AM
BMR Sales's Avatar
Former Sponsor
They also fit S10s and G-bodys
Old Apr 21, 2009 | 11:07 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
"they" being third or second gen arms?
Old Apr 21, 2009 | 12:50 PM
BMR Sales's Avatar
Former Sponsor
The third gen arms, 2nd gen arms will bolt in but are an inch or so longer. (from the poly joint to the ball joint)
Old Apr 21, 2009 | 12:52 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
which would give more negative camber correct?
it would also push the wheels out about half an inch or so.
Old Apr 21, 2009 | 02:08 PM
BMR Sales's Avatar
Former Sponsor
Yes, I was talking to soultron about this a few months ago. Basically the drift crowd of 3rd gen owners was looking at using the 2nd gen lowers to get a little more tire to chassis clearance so they could improve the steering angle on their cars.
Old Apr 21, 2009 | 05:07 PM
Twin_Turbo's Avatar
Do these numbers mean anything to anyone? 461860 & 461859
They must be old GM part numbers, can't find anything on them.
Cleotiz
Jan 6, 2018 08:56 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
