What can I adjust to bring the tire more inward?
Old Jun 22, 2009 | 05:31 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
My front tires sit like this: Passenger----> l --- \ <-----driver
What can do I ask a shop to adjust to make them like this: l --- l ?
Old Jun 22, 2009 | 05:37 PM
Stephen's Avatar
Car: 87 GTA
Re: What can I adjust to bring the tire more inward?
I'd look at the upper strut mounts first. Maybe 1 side has loosened just enough to allow to slide all the way inwards.
Old Jun 22, 2009 | 05:49 PM
Guest
Guest
Posts: n/a
I take it that is looking at the car from the front? That is camber, as mentioned its an adjustment of the strut mount. Negative camber is tilted inward at the top like your diagram, the factory spec calls for 1 degree positive but I would not do that I'd run them at zero or slightly negative (half a degree) if you get a new alignment.
Old Jun 22, 2009 | 06:17 PM
Car: 1994 Trans Am
Thanks guys, right after I posted this I thought about those. I pulled them as far as I could to match opposite the pass side and it looks much better.
Old Jun 22, 2009 | 06:20 PM
Stephen's Avatar
Car: 87 GTA
How are your tires? You'll need a good alignment now to save the tires from any future damage.
Old Jun 22, 2009 | 06:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you really need to have the car aligned. The tires may "look" better, but will get eaten up real quick if they are just eye-balled into place
Old Jun 22, 2009 | 06:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's a special tool required to do alignments on third gens. When you loosen the adjustment bolts at the top, the strut can move forward and backward as well as inward and outward.
Simply moving it inward or outward to make the tire more straighter with the camber will usually screw up the caster.
Take it in to an alignment shop and have the alignment done properly. The best you can do is eyeball the alignment just to get it to the shop. Don't worry about telling the shop what you think needs to be done. Just tell them that you need a front end alignment.
Old Jun 23, 2009 | 12:43 AM
Car: 1994 Trans Am
I'm getting an alignment this week for sure, I just lowered the thing too. Thanks guys.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Strick1
Sep 4, 2015 07:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
