Moog spring installation with tubular control arms
Old Jun 26, 2009 | 11:51 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Hi,
I am trying to install my Moog 5664 front springs with Umi's tubular a-arms and have a few questions. Do I need to index the springs? I know the stock a-arms have 2 drain holes that the end of the spring should sit between, but the Umi a-arms do not that these. Also, does anybody have any tips as to how I can get these springs installed? I don't know how many times the spring compressor has slipped off of the spring today.
Old Jun 27, 2009 | 12:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Moog spring installation with tubular control arms
put the open end of the spring to the rear of the pocket, in the center.
What compresser are you using? i never had any problems Installing these springs.
Old Jun 27, 2009 | 03:29 PM
dust3r's Avatar
This one:
http://toolsandmore.us/index.asp?Pag...ROD&ProdID=331
Old Jun 27, 2009 | 05:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've never used the one you show, so I can't comment on it. Post #3 in the following link, however, shows the one that most members use, including me. It's always worked, but the whole business of compressing springs scares the heck out of me. I'd recommend a chair through the spring and arm for a bit of protection/safety.
JamesC
Old Jun 27, 2009 | 07:02 PM
50bmgshooter's Avatar
JamesC
make that a CHAIN
Old Jun 27, 2009 | 08:08 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
dust3r; I have that same one and have never gotten it to work on any of my thirdgens. Either the "claws" end up stuck between the spring and pocket or the threaded end sticks out farthur than the spring. It works really well on longer springs, though.
Old Jun 27, 2009 | 08:16 PM
Stephen's Avatar
Car: 87 GTA
I've never needed a spring compressor at all (not even on stock springs), on the front springs, just used the chain for safety. And of course, never needed a compressor on the rear springs either.
Old Jun 27, 2009 | 10:42 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
I have UMI's control arms with my stock 1LE springs. I used the same spring compressor you showed (free rental at AutoZone). I indexed the springs as per stock and taped the insulators on the springs with electrical tape. When using that compressor I installed it with the fingers pointing straight towards the center of the car and as close to the inner edge as possible. The screw has to be as vertical as possible. With this technique it pulled the spring into a slight curve that made it easier to install.
Old Jun 27, 2009 | 11:08 PM
dust3r's Avatar
Should I be compressing the spring before I stick it between the a-arm and k-member, or should I place the spring in the a-arm, jack up the a-arm, and then use the spring compressor?
Old Jun 27, 2009 | 11:24 PM
91 1LE's Avatar
Car: '91 1LE
I installed the spring onto the control arm while the arm was off of the car. If your arms are installed you should loosen the bolts and pivot them until they are hanging straight down. You can then install the spring onto the arm, compress, and swing it up into place. And don't forget to retighten the control arm bolts.
Old Jun 27, 2009 | 11:41 PM
dust3r's Avatar
Thanks guys! I will try again tomorrow! I will be sure to post up pics when my suspension/brake upgrading is complete.
Old Jun 28, 2009 | 06:45 AM
JamesC's Avatar
Originally Posted by 50bmgshooter
make that a CHAIN
Actually, I always use a chair. Fitting a leg or two in the spring, of course, is very difficult and time consuming, but well worth the effort .
JamesC
Old Jun 28, 2009 | 08:19 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
JamesC
i got a good laugh out of you chair suggestion and this response. Thanks!
Old Jun 28, 2009 | 06:32 PM
I use a chair too.
Instructions for use of chair:
1. Place chair near vehicle.
2. sit on chair (drinking your choice of beverage) and watch friends work on
Vehicle while you give "Pointers".
3. Your friends wont always approve of this use of a chair, but I find feeding
them steak and beer will help!
LOL.
Old Jun 28, 2009 | 06:46 PM
Originally Posted by drknow90rs_ss@y
I use a chair too.
LOL.
ive tryed this method but all its ever gotten me is friends leaving or a bunch of people with a hang over the next day and still the same work to do the next day
Old Jun 28, 2009 | 07:32 PM
LOL, it takes lots of practice to perfect this technique. Dont give up and remember, at the least; It is a whole lot of fun.
Old Oct 17, 2010 | 01:30 PM
Jekt's Avatar
Car: 1983 camaro
Engine: 350 soon to be 355
i have been gettin frustrated with this. the tubular a-arms are flat unlike the stockers so the sring slidestoward the outside of the car and then doesnt sit in the a-arm right. any suggestions for this?
EDIT: nevermind used tie downs that some one suggested on another post. wish i would have found it on friday and had a impac gun, arms are a killin me
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
