3rd gen frame vs 82-04 s10
Old Oct 13, 2009 | 09:34 AM
screeminchicken's Avatar
For some reason I have a feeling that the 3rd gen frame and a s10 frame are very similar. Did a lot of searching but couldnt find a definite answer.
what do u guys think??
Old Oct 13, 2009 | 09:43 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 3rd gen frame vs 82-04 s10
sorry, absolutely nothing in common. The nearest thing you'll find is the steering boxes, the calipers and the rotors. The third gen longitudinal rails are farther apart, the suspensions are entirely different, and so on. BTW, I happen to have both vehicles.
Old Oct 13, 2009 | 10:02 AM
Thanks for the sad news...I knew I was dreaming
Old Oct 13, 2009 | 10:54 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Let me guess: you were thinking that it might be neat to put the s-10 IFS on the camaro, to replace the stupid struts with upper control arms. I've had the same thought. But why do it to a third gen when the fourth gen not only comes with a proper front suspension, but also looks so much better?
Old Oct 13, 2009 | 11:25 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
The lower control arms interchange IIRC
but the k-member is shaped differently, so you have to buy a different oil pan on an ls based swap. The F-body one isn't going to clear without some cutting
-jason
Old Oct 13, 2009 | 11:52 AM
BMR Sales's Avatar
Former Sponsor
You are correct, 3rd gens, S10s and G Bodys all share the same lowers.
Old Oct 13, 2009 | 05:37 PM
Actually I was think of some short headers like these. Dont think they will work . Who was I kidding
http://cgi.ebay.com/ebaymotors/Ls1-s...Q5fAccessories
Old Oct 13, 2009 | 08:37 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Just use some '01-02 factory manifolds if you want a shortie style header
-jason
Old Oct 13, 2009 | 10:58 PM
-jason
i got the 2000+ cast iron manifolds....they will work except a o2 bung needs to be relocated , extentions made and need to get those funky looking flanges and gaskets.
all that is ok but nobody around me is real intrested in welding cast iron..dont know why
so guys in ur surf and search adventures have you guys seen anyone meke short headers for 98-02 fbodies without those air tube ports and that has some slip fit or ball and flange or 3 bolt flange that are the same kind left and right ??
was that too many requirements!! i hope not. fingers crossed
Old Oct 13, 2009 | 11:30 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
3rd Gens, G-bodies and S10s all share the same front springs. Actually the S10 shares more front suspension components with the G-body than a 3rd Gen.
Old Oct 14, 2009 | 02:34 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
would this be possible?
im thinking no, but i have access to an 83 or 84 s10 that could have parts stolen from...
interesting
Old Oct 14, 2009 | 08:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can drop the whole Camaro body on an S10 frame.
See the AWD thread in here, and check out the many Camaro 4x4's in the world.
https://www.thirdgen.org/forums/susp...ml#post4314454
bjpotter
Jan 22, 2019 12:27 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
