removing steering column
Old Oct 14, 2009 | 04:09 AM
birshking's Avatar
Car: 1985 camaro iroc z-28
Engine: 5.7L
hello, i have an 88 camaro without tilt steering. i would like to replace it with a column that has a tilt option. has anyone out there have the answers to how i can remove the column.
Old Oct 14, 2009 | 07:15 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: removing steering column
very simple. Under the hood, first disconnect the steering shaft from the column.
Remove any plastic panels under the column. There are 3 bolts in the firewall at the base of the column. I believe they are either 10mm or 13mm heads. Remove them from the inside. Then there are two larger nuts towards the top of the column that holds the column up to the dash. Remove them. Unplug all of the wiring harnesses and pull out the column. 30 minutes at the most.
Old Sep 11, 2010 | 12:58 AM
potterc32's Avatar
Car: 1985 Pontiac Firebird S/E
Engine: 350, .5 lift cam, Holly 650
Transmission: Monster Transmission 700R4-2K stall
Axle/Gears: 4th gen 10 bolt, 3.42
would this be necessary if i'm installing headers?
Old Sep 11, 2010 | 06:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Headers built for a thirdgen shouldn't require messing with the column. Should you wish more info, posting in the exhaust forum might be the best bet.
JamesC
Old Sep 12, 2010 | 10:05 AM
Some headers you have to lift the motor to get them in. Pulling the column might be ALOT faster and easier than that, if that solves the problem. Also, some headers will hit the column, wherever it happens to be in the particular car, since there's a fair amount of tolerance in its mounting location; you can slot the screw holes at the firewall and move the column over toward the fender a little bit, it's amazing how much improvement in clearance just ¼" of that can make sometimes.
Old Aug 1, 2016 | 08:27 PM
patricks85z28's Avatar
Car: 1985 camaro z28
Engine: 283 chevy
Would this work for the 1985 z28 model also
Old Aug 1, 2016 | 09:14 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Yes it will.
Old Jul 19, 2021 | 12:32 PM
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
Whats the easiest way to remove elec, plugs and cable from column in 3rd gen firebird
ps dont have a lot of room to open door wide enough.
rgauder
May 12, 2017 06:11 PM
Ziggyman
Dec 28, 2008 01:09 AM
War_Eagle
Feb 15, 2003 10:44 PM
