lower control arms and panhard bar dimensions
Old Mar 31, 2010 | 09:04 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
i am in welding class and was thinking about building some lca's and a panhard bar and was wondering if anyone knows the dimensions of them and what size tubing i should use
Old Mar 31, 2010 | 10:37 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: lower control arms and panhard bar dimensions
I don't know the dimensions, but I could measure some stuff if nobody else responds by sometime tomorrow. Material wise, think I'd make them out of tubing in the range of 1.5"-2" and .085"-.135" thick. Use some rod ends, and make them adjustable length if you want to go all out.
Old Mar 31, 2010 | 10:40 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
lca 19.25" center to center i had 3 old panhard bars laying around, i know i made one into a tool, i can't find the others. anyway put a adjustable rod end on the panhard bar, that would be cool.
Old Mar 31, 2010 | 11:07 PM
Stephen's Avatar
Car: 87 GTA
Off my 87 GTA I get.....
PHB - 42 7/8"
Eyelet width - 1 7/8" (appears to be aftermarket bushing)
LCA - 19 3/8"
Eyelet width - 2 3/8" (stock bushing)
Old Mar 31, 2010 | 11:27 PM
89lt1's Avatar
wow thank you guys for the quick response but i dont think i will have time to make them adjustable(would like to though) i will probably get most of materials free if my instructor lets me... other than bushing and what not
Old Mar 31, 2010 | 11:31 PM
Stephen's Avatar
Car: 87 GTA
You'd want to consider making the PHB adjustable, at least.
Even with stock parts at stock height, my rear axle was offset to the passenger side by about 3/4". So I HAD to buy the adjustable one, to get my 315s to fit.
do you ever watch "extreme 4x4"? Ian makes them all the time. its really cool they way he does it. i made my lcas from a truck tie rod, the ends are isuzu npr pilot bushings.
Old Apr 1, 2010 | 08:26 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Yes I watch Extreme and it is an awesome show. I started watching it just for the fabrication they do but now I'm considering a truck build for a winter beater.
To stay on topic, your LCA sound interesting. Have any pics of the setup?
Old Apr 1, 2010 | 11:12 AM
here is the driver's side. passenger side looks the same...
Old Apr 1, 2010 | 11:52 AM
Car: 1987 IROC-Z
Transmission: TH350
do you have a better picture? you can't really see it in this one.
1992rs/ss
Jan 31, 2025 05:10 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
