squeaky sfcs ??
Old Dec 2, 2000 | 04:30 PM
andrew350's Avatar
squeaky sfcs ??
has anyone else experienced a lot more squeaks AFTER they've installed sfcs?
I guess its winter now, and that could be an outside factor, but both me and my brother installed sfc's a few months ago, and both of our cars are squeaking.
Mine squeaks like mad, but I attribute some of it to my poly bushings. But we both hear similar sounds at the base of our doors & perhaps T-Tops.
Because we used similar subs, and installed them using the same technique, I would like some outside input as to if this is common. Has anyone else had this problem? Any suggestions to fix it?
Old Dec 3, 2000 | 09:19 AM
ede's Avatar
ede
sfc's should cut down on noise since it makes everything stiffer ,less movement.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 3, 2000 | 09:21 AM
ede's Avatar
ede
are they bolt ins? that may be the problem if they are. weld in type should make everything stonger and reduce squeeks.
1st & 3rd
Old Dec 3, 2000 | 09:32 AM
merf23's Avatar
did you replace your door hinge pins and door/hatch seals...the seals make a huge difference
Old Dec 4, 2000 | 02:29 PM
andrew350's Avatar
1. They were weld-ins (only way to go).
2. Nothing else changed/replaced after installation.
I agree that some parts could/should be replaced due to excessive wear, but the problem wasn't there before, now is. Sounds kinda fishy to me. The thing is, its in both of our cars (mine and my brothers). Could we have done something wrong? I doubt it. We have a pretty good clue about our cars. ??? I was just wondering if the new stiffness could cause a squeak somewhere? Sounds kinda backwards, I know. But this is annoying/confusing.
Old Dec 4, 2000 | 06:31 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Replace the upper door hinges,and the squeaks will go away. But replacing these hinges is not for the faint of heart. They are a real bitch.
By the way. If anyone is interested? I may have finally solved the third gen "upper door hinge" problem permanantly. You can now do both sides in an afternoon. Just thought I'd pass it along.
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side not too bad
Old Dec 7, 2000 | 10:27 AM
andrew350's Avatar
Cool. I think I will change those hinges.
But here's another thing... sometimes when I sit in the car, door open (not moving), I hear the undercarrage squeak. This can only be coming from the subframe area. Could there be a rubbing? I know I'd have to look for myself. Something is up. I guess I'm the only person to experience such aggrivation.
Anymore basic ideas of how to get rid of those pesky squeaks? Does winter make poly bushings squeak more?
Old Dec 7, 2000 | 05:12 PM
IrocStan's Avatar
What about your the front bushings in your LCA's. When you welded your SFC's to the LCA mounting bracket you may have burnt the grease off or burt the rubber if you welded while they were connected. Check to see if the bushings are lubed enough. I bet that is your problem.
87 IROC 350, 3:42 Torsen, pocket ported 083 heads, complete Edelbrock exhaust, Most free mods, Most little mods, aluminum d/s. Edelbrock STB, SSM sfc's, boxed rear suspension pieces, urethane bushings everywhere.
Stock cam, chip, runners, base, and trans
13.94@103mph, 2.25 60'
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Hoping for 12.999
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
