Aftermarket Springs
Old Feb 6, 2001 | 05:57 PM
Metalifann's Avatar
Aftermarket Springs
Does anybody make an aftermarket spring that has a stiffer spring constant without sacrifising ride height? I'd love to get some performance springs but the speed bumps at USF are wicked and I'm already scraping my air dam on them with the stock springs.
Old Feb 6, 2001 | 06:06 PM
ede's Avatar
ede
check out the jegs or summit catalog. a lot of the makers of suspension parts make springs, plus you should be able to find something from the local parts store.
ICON Motorsports
1st & 3rd
Old Feb 6, 2001 | 08:20 PM
Metalifann's Avatar
I know that there a lots of springs out there, but all of the springs in Jegs and Summit lower the car as well. I need to maintain the same ride height.
Old Feb 6, 2001 | 08:37 PM
89GTA5spd's Avatar
just a shot in the dark here.. but maybe you can get 1LE springs from your local car part store. It's worth a try at least. I know those are stiffer than the WS6 springs.
Old Feb 9, 2001 | 01:41 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Don't always asume that what you see in the catologs is all that they have. I know for a fact that Summit carries more than twice what the big catolog sells. Just call them and tell them what you want. That's all that I ever do. Forget the catolog.
Also, many spring manufacturers make performance, or "heavy duty" springs that are stock height.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 9, 2001 | 07:14 AM
ausrs's Avatar
find a spring manufacturer that has the specifications from GM
even in aus i found a company called kmac suspension
they made me standard height BUT 20 % stiffer than iroc ..so should be easy in usa !~
Old Feb 9, 2001 | 11:43 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
I know what your saying about the speed bumps at usf i live in port richey and have had to go there a few times(helping friends and going to the gym a few times) i see all sorts of cars scrape and get stuck i have helped a few low riders off the bumps myself. my 83 camaro scrapes aidam when im there to. maybe the students should complain a little more. i k now when i was in high school up here in port richey they put in new speed bumps that were extremely high. My friend cracked a ground effect and had the school replace it and they wound up puttin in new bumps that werent as bad
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
MUSTANGS SUCK
Old Feb 10, 2001 | 09:46 PM
Metalifann's Avatar
I ended up ordering some z28 springs from Advance Auto parts (I work there). The book said that they were around 600 lbs./in. (i forget the exact #'s). It also said that my RS springs were around 400 lbs./in. I figured that would be a significant difference. Plus they were only like $50.
87v6Bird
Jul 1, 2018 04:12 PM
customblackbird
Oct 1, 2015 04:30 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
sandman92084
Sep 12, 2015 10:27 PM
crzycamaro86
Sep 12, 2015 05:51 PM
