How strong is a 9 bolt?
Old Feb 8, 2001 | 05:52 PM
84TransAm's Avatar
Well, i'm about to "inheret" one and was wondering how much hp/torque it will sustain. Also, as of now i have the stock Drum brakes and was also wondering what is involved in a drum to disc swap. I also need to know if any custom parts/setup will be needed before i start doing this swap. I just hope it is as easy as the make it look on Hot Rod TV (they never curse or have any problems)
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Old Feb 8, 2001 | 10:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All my best times (below) were with a 3.27 geared 9 bolt and slicks.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Feb 9, 2001 | 06:57 AM
ausrs's Avatar
9 bolt is strong enough to take 400 hp according to the people who designed it in aus LS1 commodores run through the same gear sets that you do even modded ones
btw gear sets available for 9 bolt go from 2.7right the way to 4.11 in aus ...
even in usa they where the HP option instead of the crappy 10 bolt
Old Feb 9, 2001 | 09:08 AM
84TransAm's Avatar
Would the stock gears from my current 10 bolt fit the 9-bolt? Also, how come there is no listing in Jeg's or Summit, is there a different name i should be looking for?
Old Feb 9, 2001 | 12:55 PM
GMI FAST's Avatar
Times in sig are with 9-bolt and SLP 3.70's. Never had a problem...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 400" CNC Bow-Tie Tall-Deck, Accel Pro-Ram, DFI, AFR heads, HRC T76 Turbo, NOS 150-hp dry kit, TH400 w/GV overdrive, 12-bolt w/3.70 gears, 8-pt. S&W rollbar, Spohn suspension, 18" wheels, Baer brakes
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Old Feb 9, 2001 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There is no listing in Jegs or Summit because the 9 bolt is only an f-body option in north america and not all cars have them making aftermarket sources very few.
Nothing internal between a 10 bolt and a 9 bolt is the same. The only thing these diffs have the same is external mounting hardware.
There are some suppliers that carry a few gear choices but the gears are expensive.
Old Feb 10, 2001 | 03:31 AM
ausrs's Avatar
if anyone would like some info on where 9 bolt parts can be obtained (in aus) email me
complete instal kit bearings seals etc around aus$600 which will be around 400 usa$with freight my guess
btw these rears ends have been used in aus since 1977 and are still used today
also have heard that a company called spicer has bought dana ...and borg warner so maybe someone in usa will get parts
[This message has been edited by ausrs (edited February 10, 2001).]
Old Feb 10, 2001 | 01:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Last I checked, www.ring-pinion.com and www.drivetrainspecialists.com sell 9-bolt gears, but only 3.70's to replace your 3.27 and 3.45 gears. They wont fit 2.77 gears.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 10, 2001 | 04:57 PM
MikeDwhoROCZImports's Avatar
RUNNING HIGH 10's WITH THE 9 BOLT!!!!! WTF. I guess my 9-bolt must have been seriously messed up when I bought it used. I've got an LG-4 and run mid 15's, and I busted the pinion when street racing.
Old Feb 11, 2001 | 06:19 AM
ausrs's Avatar
ratios for 9 bolts that ARE available
2.7....
3.08
3.27
3.54
3.70
3.89
4.11
they are availabe and are still being made today in aus for aussie cars dont listen to what shops tell you is and isnt being made they ARE available and stronger than 10 bolt
Old Feb 11, 2001 | 06:22 AM
ausrs's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
</font>
try australia it is still the rear end being used here by GM holden AND fraud dont need aftermarket ANY rear end shop in aus fixes these rears every day
Old Feb 11, 2001 | 10:51 AM
AlkyIROC's Avatar
Car: 87 IROC L98
That's nice to know but by the time it takes to get a set of gears shipped to north america, the cost will be even higher.
If someone is determined to run a 9 bolt and needs the lower gears, then buying a set from AU isn't a problem. When you consider the final cost and the fact that other needed parts such as larger axles and carriers are either not available or priced to high to be affordable, building up a "Better 10 bolt" or buying a drop-in 9" becomes a better choice. At least if you break parts in these, replacements are easily available.
If you live in AU then running a 9 bolt is your best option but then you wouldn't want to drive a Skoda either.
Old Feb 11, 2001 | 05:53 PM
ausrs's Avatar
LOL @ the skoda remark
btw everything that we in aus get for our cars takes a week or so to get parts
costs (i believe) getting the parts over to usa for the stronger of the 2 rears available in usa for 3rd gens i just keep watching threads that say parts are not available all it needs is one place (like the links you posted NOT to lie to you about availability of parts and stocked some there wouldnt beany problems i have been told that parts havent been made for 9 bolts for 10 years ...parts suppliers in usa are lieing to you THAT is the problem
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Whata69
Mar 2, 2016 06:34 AM
Amillionoh7
Sep 11, 2015 11:36 AM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
