Ride height survey - how low is your car?
Old Mar 12, 2001 | 01:22 AM
PerthZ28's Avatar
If I measure from the ground to the top of the wheel arch, I get:
Front: 695mm [
Rear: 710mm
This is a stock '85 Z28 with 245/50/16 in front and 255/50/16 out back.
If I use the Jamex springs, it will lower the car by 1.5" [38mm]. That will make it about 655mm at the front. Too low??
Old Mar 13, 2001 | 07:26 PM
buddman91rs's Avatar
sorry i only know that stuff in inches....my ride height is 7 inches at the front center bumper and about 4 inches at the little plastic thingy underneath....and ive got about a inch between the wheels and the fender lip w/ 245/50-16's all the way around
i was thinking about lowering my car about a 1/2 to 1 inch but nobody sells springs like that oh well..........
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
GONE MUSTANG HUNTING.......
BACK IN 10 SECONDS
Old Mar 13, 2001 | 09:24 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If i remember correctly, it is 26 inches in the front and 26.75 inches in the back to the tops of the wheelwells.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Mar 13, 2001 | 09:49 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
25.5" in the front
27.0" in the rear
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Mar 14, 2001 | 03:25 PM
oh to the tops of the wheel arches
on mine it's 26.5 up front and 27 out back
1991 RS LO3
aol s/n: budman8503
BACK IN 10 SECONDS
Old Mar 19, 2001 | 03:07 AM
PerthZ28's Avatar
695mm works out to be 27.4" in the front. If I lower it to 26", is it gunna be too low? Am I gunna hit every curb in town?
Old Mar 20, 2001 | 08:09 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
Right now???
about three feet.
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Mar 21, 2001 | 08:59 PM
82camaro's Avatar
Car: 82 camaro SC
Keep in mind that 1.5 inch drop doesn't mean your car will drop 1.5 inches. Your car might be sagging a little from old springs, or just a little bit lower than most third-gens and you could end up with a 1 inch drop. Or, it could be the other way and your car could sit higher than a typical third-gen and you could get a 1.75 drop. Every car is a little bit different. With drop springs "results may vary"
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 22, 2001 | 11:08 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
My measurements: 26-1/16" (662 mm) f, 26-5/8" (676.28 mm) r. Measured at the center line of the rims to the fender lip. 90 Camaro RS Convertible with less than 1 year old Eibach Pro-Kit springs. Also keep in mind that even though you will have lower ride height you may scrape about the same as you do now. These springs are a lot stiffer than stock ones. So there is less weight transfer forward under hard braking. I scrape no more than I did before with my old tired sagging 10 year old stock RS springs. Also replacing the shocks and struts with good aftermarket ones (Bilstein or Koni) will help with this as well. I have Bilstein HD. Good luck, Lon.
[This message has been edited by lonsal (edited March 22, 2001).]
Old Mar 23, 2001 | 07:57 PM
kevinc's Avatar
Car: 1982 Z28
Front: 26 7/16"
Rear: 27 1/4"
The fronts are Moog part# 5662 with 3/4 of a coil removed.
Rears are stock '82 progressive-rate crap that came on it, they hook like a mother in the corners so why change a good thing?
-Kevin
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
customblackbird
Aug 15, 2021 10:16 PM
Linson
Aug 21, 2015 02:12 PM
novaderrik
Aug 10, 2015 12:44 PM
