cutting down springs
Old Apr 8, 2001 | 09:32 AM
blue91rs's Avatar
I wanted to lower my front end about 1.5 inches after i put in some after market springs that where supposed to be an exact match for the oe, with a heavier spring rate. They actually raised my vehicle about an inch, and it just doesn't look right. I was wondering how hard it would be to cut about an inch and a half off with a sawzal, and how I should do it in order to not run the spring? TIA
Old Apr 8, 2001 | 01:07 PM
Camaro_hunter_d's Avatar
but the lowering springs...period. You should never cut a spring no matter what anyone says.
Old Apr 8, 2001 | 02:24 PM
BigMike 92 Z28's Avatar
I cut my Springs- I got the Eibach Lowering springs and it was stock hieght in the front, so I took them out and cut off a half of a coil with my portable band saw and put them back in- do this process over and over intell you get the ride height you want. Ive herd of bad things happening to people with cut springs but I have had 2 camaros and a S-10 truck all with cut springs and never had a problem! ( just take your time and cut a small amount at a time - if you cut to much your screwed!
1992 Z28 W/5.7L. Teal with unpainted cowl hood,18" Billet Specialities Rims,Eibach Sportline Springs, Leather int., B&M Mega Shifter, Headman Headers, Flows,No Cats,K&N,HyperTech air foil,Custome Burned Chip,MSD Ignition,Shift Kit, Billet Corvett Servo my Back License plate reads "ALL UL C"
Here's a pic of my car
http://www.geocities.com/jonnyarson/maro.jpg
" WHAT DOES THE BACK OF A MUSTANG LOOK LIKE "
[This message has been edited by BigMike 92 Z28 (edited April 08, 2001).]
Old Apr 8, 2001 | 04:04 PM
blue91rs's Avatar
I'd buy the lowering springs, but my monetary situation is tight, I'm sure we can all relate to that.. What sort of bad things happen to people with cut springs? If the top of the spring is flat making it mount properly, and I don't take off too much, am I really taking a big risk?
Old Apr 10, 2001 | 08:02 PM
Timmys88Z's Avatar
<font face="Verdana, Arial" size="2">Originally posted by blue91rs:
I'd buy the lowering springs, but my monetary situation is tight, I'm sure we can all relate to that.. What sort of bad things happen to people with cut springs? If the top of the spring is flat making it mount properly, and I don't take off too much, am I really taking a big risk? </font>
i'd like to know as well, anybody?
Old Apr 13, 2001 | 08:12 PM
Id just do it whith the stock springs( dont cut too much though )- i had it done on my rs and it was fine for over a year ( and i drove a lot of miles real hard ) Ive herd of peopls springs poping out of place and stuff like that but never seen it in person on any of my cars or any of my friends
Here's a couple pics of my car
http://www.iroczdesigns.com/images/camgf.jpg
http://www.iroczdesigns.com/images/cam5.jpg
[This message has been edited by BigMike 92 Z28 (edited April 13, 2001).]
Old Apr 14, 2001 | 09:48 AM
OLDYELLR's Avatar
Car: '85 IROC
Yes, you have to be very careful cutting the front springs. Remember that they sit about half way between the wheel and the LCA pivot point, so the car will drop a lot lower than you might expect.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Apr 14, 2001 | 10:58 PM
FlashGTA
Guest
Posts: n/a
What I have heard is you should never cut springs using a torch because it weakens the spring. I've never heard of not cutting them using a cutting wheel or saw.
Old Apr 16, 2001 | 12:21 AM
rhawki's Avatar
You're not supposed to cut them because they are designed with a specific spring/coil rate, so when you cut them, you also remove some of the springs potential to do it's job. For example, if you remove a "clicky" pen spring and cut a bunch of coils off, it's clicker will be all f'ed up, but if you just take a little off, you won't notice - not that any sane person would do this with a pen Drop springs will have the same pressure as stock, but they're designed a little shorter through tighter windings, or progressive windings or whatever.
I've read that if you're gonna cut them anyway, never take enough off to drop it more than an inch or so (1&1/2 at most) Also, you have to have a spring that has at least one "wild" end to cut it, if both ends are tapered level, you can't cut it...
-Rich
gta892000
Aug 11, 2019 11:16 AM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
FormulasOnly
Sep 6, 2015 10:42 AM
