Which 4th gen rear susp takeoffs fit 3rd gen
Old Apr 11, 2001 | 01:13 PM
Mike-88CamaroTBI's Avatar
SLP has great deals on take off shocks, springs, LCA's and Panhard bars. I intend to freshen up the rear end of my car as my next major project on it. My user name describes the car pretty well. I have a few questions
Is my understanding correct that the 4th gen take off shocks fit 3rd gens correct?
Is my understanding correct that the 4th gen take off springs fit 3rd gens correct?
Will 4th gen rr springs be a stiffer spring than my 3rd gen springs (I hope,I hope).
Is my understanding correct that the 4th gen take off LCA's fit 3rd gens correct?
My idea on the LCA's is to push out the rubber bushings and press in some poly bushings and have them ready to bolt up(maybe even reinforced as well).
Thanks in advance for sharing your expertise on this guys.
Mike
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer mike.davis@firstunion.com
Old Apr 11, 2001 | 03:46 PM
Tas's Avatar
Tas
4thgens have the SAME rear suspension design except for the fact that the rears are about 2" wider on each side. The 4thgen spring would probably be better than the one you got since you don't have a WS6 or a IROC.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
<font face="Verdana, Arial" size="2">quote by -Tas
"Church of the Sleeping In Late". I am the preacher. Give me your money.
</font>
Old Apr 12, 2001 | 12:11 PM
RGZWS6's Avatar
Wouldn't being two inches longer move the shock mounts to different locations? What is the difference between stock 4th gen shocks and 3rd gen WS6 shocks?
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Apr 12, 2001 | 05:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
4th gen rear suspension pieces are identical to 3rd gen stuff. But 4th gen front suspension pieces are totally different and will not fit. That means rear springs, rear shocks, LCA's, PHR, and torque arm are interchangeable, while the front springs and shocks are not.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 13, 2001 | 12:07 AM
Drew's Avatar
I thought I read somewhere that the mounting points on the 4th gen were differen't for the shocks and springs... the rest should interchange fine, but you may want to double check the springs and shocks, besides there are better aftermarket springs and shocks available, and you'd want all four springs to be matched.
Old Apr 13, 2001 | 05:25 PM
Tas's Avatar
Tas
nope. you can bolt a 4thgen rear right in if you wanted to use 4thgen, or C4 and C5 Vette rims without spacers in the rear. You'd still need spacers in front though.
-Tas
Old Apr 20, 2001 | 10:47 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The extra width on the fourth gen axle is at the VERY end, past all the mounting points. All the 4thgen rear suspension stuff should bolt in fine.
Old Apr 20, 2001 | 03:12 PM
DaveZ24's Avatar
So, if I want to put 2001 WS6 springs and shocks in my 84 Firebird it would be little to no trouble?
One Man...One Search...One Goal...MORE POWER!!!!
84 V6 Firebird in sad, but mechanically sound shape. Currently gathering parts for a performance restoration, i.e. restore the body and interior, then stuff as much HP under the hood as possible.
Any body know of a good resto shop??
Just a Nitro guy living in a Nitro world!!!!!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
