Jingling noise from my wheels
Everytime I hit a bump I here a jingling noise from my wheels anyone have this problem before?
86 T/A 305 4BBL NO AC,'83 center console (because I like the look), '83 L69 being rebuilt now, and new beige intreior going in soon
Yes, it was in a Toyota pickup that had all of the lug nuts loose - not even finger tight.
My first check would be to jack up the car, hold the wheel from both the 6/12 o'clock and 3/9 o'clock positions and see if there is any excessive movement.
If so, and the wheel lugs are tight, check the spindle nut. It may have backup out. Remove and inspect/repack the bearings.
I could also be worn tie rod joints or any of a hundred of other things. You'll have to physically look and inspect for anything that is loose.
[This message has been edited by Stuart Moss (edited June 12, 2001).]
Car: 1991 Trans Am
Transmission: 4L60
<font face="Verdana, Arial" size="2">Originally posted by RED86TRANSAM:
</font>
</font>
Take off your front wheels and check your brakes. I once had one bolt missing on the caliper and the other loose, this resulted in the brake pad clanking around.
91 TA 5.7 TPI Automatic.
w/WS6 and 3.23 rear.
K&N Air Filter,Hypertech Coil,Moroso Blue Max Wires, Bosch Platinum plugs gapped at .050,
JET fan switch,JET air foil,Dual cats with Flowmaster 3" exhaust (Headers coming soon),
Complete PST components on front suspension, Spohn LCAs/Panhard bar.
It's not much, but it's a start and I have a Summit catalog! :-)
Check out your sway bar end-links. My car made the same noise. It sounded like someone was shaking a fist full of coins. I took a look underneath the car and the the four little rubber pieces on each link were deteriorated to the point where pieces had broken off.
If this is the problem with your car, get polyurethane replacements.
Car: 4
Engine: 6
Transmission: 5
Sway bar end-links, if it sounds like coins in your pocket.
ICON Motorsports
ICON Motorsports
Another thing to check is the flimsy clips that hold the disc brake pads to the calipers piston. Some people leave these out when putting in new pads and it can let the pads rattle.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Car: '87 IROC
Transmission: TH700R4
If it is a higher pitch jingle noise it most likely the retainer clips for the brake pads. I have the same problem since I had Midas (Never again) refurbish my rear brakes. They neglected to properly install the clips and have since fallen off. Most parts store have them for cheap.
tj
Black '87 IROC 350 TPI T-top headers 3" exh. MSD, all the ususal stuff
tj
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
i have the same problem, only my sway bar end links look to be fine and the brake pads were installed correctly. When I have people in the back seat, the noise is louder. Everytime I hit the smallest bump, it's an annoying clang. I've checked underneath because it sounds to be coming from the rear, but found nothing wrong. This noise has been bothering me for about a year now. If anyone figures this out, I think i'm up to offering a reward.
I know you said the brakes are installed correctly but you should check to see if the ears on the pad without the clip are flush against the caliper, if they are not you can take a pair of channel locks and bend the ears to make sure they are right against the caliper, this will keep the pads on the side without the clip from jingling around. Hope this helps. Good luck.
