How do i grease my Rear-Bearings???
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
mine is squeaking like all hell,
my friend is a mechanic and said that my rear bearings need to be greased......how do i do this?????
Car: 4
Engine: 6
Transmission: 5
Can't imagine... there aren't any "bearings" in the rear suspension... also nothing greasable...
You might try a can of spray silicone on each of the suspension bushings until you find whatever is squeaking. There are 4 control arm bushings, 2 Panhard bar bushings, 2 stabilizer bar center bushings, and 4 stab bar end-link bushings.
ICON Motorsports
ICON Motorsports
Go around turns. The rear wheel bearings rely on the gear lube sloshing around in the rear end for lubrication. Squeaking doesn't sound like a bearing problem though, it sounds more like you have a brake or suspension problem. When bearings go you usually hear/feel a grinding sound. If you do need to change a wheel bearing, heres the procedure:
1.)Jack the car up, remove the wheel and brake drum, and pull the diff cover to drain the fluid.
2.)Remove the pinion cross shaft retaining bolt (5/16") from the diff carrier, and remove the pinion cross shaft.
3.) Push the axle inwards and catch the c-clip when it falls out.
4.) Using a slide hammer, pull the old seal and bearing. Install the new bearing with the old one or with a bearing driver (big socket works.) Install the seal flush with the end of the housing.
5.) Slide the axle back in, put the c-clip in and pull the axle outwards to seat the clip. Slide the pinion cross shaft back in and put some blue loctite on that bolt and torque it to 20 ft. lbs.
6.)Put your brake drum and wheel back on, and using a new gasket, reinstall the diff cover. Fill it up with some new lube and take it for a spin.
I like to put a bunch of lube inside the new bearing also, and a little bit on the seal. Check the axle for wear and clean up the seal area so you don't fry the new seal up. Good luck.
3.)
-Jason M. 1991 Camaro Z28
3.)
eeeekkkk
well here's the exact problem.....
whenever i am driving the rear passenger side squeals like all hell
WHEN I BRAKE the noize goes away
whats this sound like???
Axle/Gears: 3.45, 3.27, 3.27
Slow down around those corners and the rear passenger won't have to squeal! LOL
[This message has been edited by lonsal (edited June 30, 2001).]
CarGuyDennis
137
Dec 6, 2016 11:02 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Numbah-1
Sep 12, 2015 08:57 PM
