welding in SFC'c
Old Aug 7, 2001 | 01:09 PM
ScreaminDeamin85Z's Avatar
welding in SFC'c
ok i have an arc welder that can be used for frame work. i had read on the board sometime a few months ago that you didnt want any flex/strain on hte chassis when you welded these in. how would i support the car without having flex, and i dont own a lift.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Aug 7, 2001 | 02:12 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
If you have a garage with a level concreate floor you can jack the car up and put jackstands under the front control arms as close to the wheels as you can get them and under the axle tubes as close to the rear wheels as you can get them. Make sure all the jackstands are the same height.
Old Aug 7, 2001 | 03:16 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
If you do this, will you help me weld my SFC's in also? I live in Spring, TX also. I think I met you before. I drive a dark purple RS. Let me know. Thanks.
Scott
Old Aug 7, 2001 | 03:20 PM
Saywhut's Avatar
If you're planning to weld to the floorpan, the arc welder could easily blow holes, a MIG is usually preferred.
Old Aug 7, 2001 | 03:28 PM
no im not planning on welding these to the floorpan. they attach to the frame rails.
Scott, sure man just let me figure it first i dont feel as guilty wheni screw up my car but i feel real bad when i screw others. and yes i knwo who you are, how's your sis doing? you still gonna go to NHC this semester?
Brandon
Old Aug 7, 2001 | 08:28 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Superman, is that techique safe? I would like to weld in my own but also don't have a lift yet. If welded in by your suggestion, would they work and be just as strong as if they were welded on a lift?
Old Aug 8, 2001 | 01:47 PM
ATOMonkey's Avatar
What about ramps?
Old Aug 8, 2001 | 04:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are the frame rails thick enough for an arc welder?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 8, 2001 | 05:55 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Yes,this is a safe way to weld in the sub-fram connectors. I've done it this way on about four cars and they all worked out fine. Like I said the biggest thing is to make sure thes stands have the car level to the way it sits on the ground. I have never done this with a arc welder. All the welding on frames and roll cages I have ever done has been with a mig,so your on your on on that.
Old Aug 9, 2001 | 07:23 AM
ERIC'86IROC's Avatar
A MIG welder(GMAW) is a type of arc welder, so is TIG(GTAW). If you are referring to stick(SMAW) welding I would recommend using small diameter electrodes(3/32") that are rated for use in "out of position" welding. Usually if the third number is a "1" the electrode will work well in all postions, i.e. 6010, 6013, 7018, etc... If you weld to the floor pans MIG will require much less skill and will be less likely to burn through.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
[This message has been edited by ERIC'86IROC (edited August 09, 2001).]
Old Aug 9, 2001 | 03:18 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Hi,
I'd like to get SFC's for my vert.
But, I don't know how to weld and don't have any equipment even if I did know how to weld.
I've seen the bolt on SFC's are they just as good as the weld on types??
I do know someone who is a welder and a damn good one, but he would charge a good chunk of change.
He does it for a living and there are no discounts.
Old Aug 9, 2001 | 03:35 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Sunbitz,
The bolt in type sub fram connecters are good when you first put them in. After being in a while the bolt holes elongage due to the torque and stress put on them and do no hold anymore. I would pay the little extra to have the weld in type put in.
Old Aug 9, 2001 | 06:41 PM
sunbitz's Avatar
Engine: 305 TBI
superman...
Thanks!
That makes perfect sense to me.
Never really thought of it that way.
I'll do a bit of saving and get the weld on type.
Thanks Again!!
Old Aug 11, 2001 | 05:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I've e-mailed you my recommenedation for a local SoCal shop to weld on the SFC's. BTW, only two brands work for a 'vert (Alston & Kenny Brown). Good luck, Lon.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
