lower or raise???
Old Sep 10, 2001 | 07:15 PM
87firebird's Avatar
lower or raise???
I want it to look like it has a raised rear end. whick is better to do-first of all they make a piece that you put on your coil springs and it can either raise it or lower it. the Q is, Is it alright to lower the front, or should I raise the rear. or should I even do it at all. will it look good if I lower the front, anyone ever do this.
Old Sep 10, 2001 | 08:23 PM
nicmike85's Avatar
If you raise the rear then you transfer weight to the front. This will have a negative effect on traction.
Old Sep 15, 2001 | 01:20 AM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
personally i went to 275/60/15's on my rear wheels, and 235/60/15's on the front, and there is definitely a noticable "rake" effect with the back up higher then the front. yeah it looks mean and all, but i cant begin to explain how terribly it handles. around corners my tires almost always break loose, and when i try and launch i totally go to one side or the other. different size tires are one way of making the back sit higher though.
Old Sep 15, 2001 | 07:19 AM
87firebird's Avatar
I thought about bigger tires, but my brother did that on his 79 monte carlo and every bump he hit the tire would hit the fender and it tore the crap out of the tire. Then he got thoses spacer things that go into your coil spring and it was fixed.
Old Sep 15, 2001 | 09:13 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Is the car sagging? Perhaps some new springs would do the trick.
Old Sep 25, 2001 | 11:13 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Don't jack up the rear of your car. That look is not only a very toolish look, it is very detrimental to your handling and any attempt at getting good traction......
my $.02
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Sep 26, 2001 | 03:21 AM
Tas's Avatar
Tas
Its not 1978 anymore. Keep it level and low all around.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Sep 27, 2001 | 01:45 AM
Kandied91z's Avatar
raise it up
Old Sep 27, 2001 | 07:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Dont jack the back up... Thats for back in the day when it was cool to pimp out a van.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
88SS6SPEED
Nov 11, 2015 07:05 AM
jbates346
Oct 21, 2015 01:50 PM
roysatikas
Sep 22, 2015 08:15 PM
camaronils
Sep 20, 2015 02:57 PM
