Larger mm Sway bars really worth it ??
Old Nov 1, 2001 | 10:26 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Yes? , No? , Maybe? , or "Shhh I'm hunting wabbits" ?
heh
anyway I was looking options into stoping this Dam* body role
I know I dont have Sub-connectors yet but do have .. Strut brace and lowered it ~1.75"
Just courious if you guys noticed any improvements over stock
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Nov 2, 2001 | 12:51 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I noticed a good difference when I went to the bigger bars on mine. And with the higher rate springs and new shocks/struts,the car virtually lays flat around the tightest corners. I would definitly recommend larger sway bars if you're looking for reduced body roll.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
Old Nov 2, 2001 | 01:09 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
They made a HUGE diffrence on mine too. if you want to really reduce body roll, they help, but also get shocks and stuts.
Old Nov 2, 2001 | 07:53 AM
82camaro's Avatar
Car: 82 camaro SC
Made a huge difference in my 82. But I went from 7/8 front to 1 5/16 and no rear bar to a 1 inch rear bar. You need a combination of parts to get rid of the body roll. Sway bars, shocks, struts, springs, SFC's, minimum 16 inch wheels, performance alignment, just to name a few.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 2, 2001 | 08:39 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
big difference in handlingg... added iroc sway bars and a wonderbar to my rs and it made a big difference in corning and body roll. i highly recommend it.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets,posi 323 , lt1 cam and new valve springs
Old Nov 2, 2001 | 10:49 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
ahh sounds good
I do have springs and shock and struts
(I want to get better shocks and struts though)
which brand bars would you recomend getting ..brand/size???
Hecubus
Old Nov 2, 2001 | 11:01 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes. Big difference. But done as a complete suspension upgrade package.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Nov 2, 2001 | 04:19 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I put the 1LE size bars on, i think they are the biggest they made stock, and i have heard people say that going any bigger will cause more problems.
mine are 36mm hollow front/24 mm solid rear
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
