how to measure swaybar
Old Dec 11, 2001 | 03:53 PM
88greyiroc's Avatar
i am really retarded and i can't figure ouit how to measure it i took my tape and went around it and got 4 3/4 ".what am i doin wrong.
1988 Iroc-z (Gun MetaL)
350TPI (38K MILES)
700r4 stage 2 shiftkit
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 11, 2001 | 04:01 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Take a cresent wrench and adjust it to fit tightly around the sway bar,pull it off and measure in between the jaws of it and thats your swaybar size.
Old Dec 11, 2001 | 05:06 PM
88greyiroc's Avatar
thanks alot i really appreciate your help your a life saver mechanics want so much to do so little
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 11, 2001 | 06:15 PM
82camaro's Avatar
Car: 82 camaro SC
You can also convert your measurement around the bar. 4.75 comes out to a little over 36mm. I would guess you have the 36mm bar.
4.75 / pi * 25.4
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Dec 11, 2001 | 08:13 PM
88greyiroc's Avatar
i just done what the other guy told me to and i got 4 cm .does that work out to the same?
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 11, 2001 | 10:38 PM
82camaro's Avatar
Car: 82 camaro SC
4cm=40mm
82camaro
Old Dec 13, 2001 | 08:16 AM
88greyiroc's Avatar
if mine is 36mm does that mean my car has a special package?
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 13, 2001 | 09:06 AM
gravitar's Avatar
It means you have the biggest stock bar the factory produced. Most people are satisfied with the performance they get with a bar like yours.
Old Dec 13, 2001 | 10:58 AM
88greyiroc's Avatar
would there be a way to tell if your bar is bent?what would be some side effects?i am just curious
350TPI (38K MILES)
3" cat back exhaust
K&N
Mod Chip
8.8 Race Wire
accel everything
2.77 limited slip
T-Bar roof
Old Dec 21, 2001 | 11:12 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The sway bar ends should be level, when the car is sitting on a flat surface. If it is bent, the car will sit lower on one side. You should be able to determine this simply by measuring the distance from the top of the tire, to the fender lip. They should be equal. (within a few 10ths, anyway)
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Jul 1, 2018 04:12 PM
AUZ28
Oct 3, 2015 06:28 PM
