Rear PBR caliper Q
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Rear PBR caliper Q
After looking at a couple 4th gen rears in a salvage yard, the rear PBR calipers look exactly like my 89s. Are they the same?
Thanks...
Damn Jeff Gordon...
Thanks...
Damn Jeff Gordon...
Car: 1986 Firebird
Engine: 2.8 V6
<chokes on coffee> Huh?! For real? The backing plates... they'll bolt to our disk brake axles? Not that I've ever seen a 4th gen in a junkyard in NJ, but...
-Tom P (Hot rodded 1986 Firebird 2.8l)
The 93-97 rear brakes are a pretty easy swap. The only thing you have to modify is the "brake weight". Since the thirdgen rear is 3" shorter that brake weight gets into the LCA mount. You can hack it off and flip it around, that's what we do. Or you can probably just eliminate it, it doesn't really do much functionally, GM put them on to dampen vibrations (supposedly).
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Steve
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
<font face="Verdana, Arial" size="2">Originally posted by TomP:
The backing plates... they'll bolt to our disk brake axles?</font>
I was mainly concerned with the calipers but it's an interesting topic. I'm still considering a 4th gen rear to some extent I suppose. I asked the guy what they were getting for those rears and he said "About $600". Yeah right...
I figured they could be used if I needed a core or jsut one to have around in a pinch.
Oh yeah...what the heck is the "brake wieght" Steve talked about? I thought those were on the pre-89 type?
Thanks.
Thanks.
The 93-97 cars have some sort of brake weight on the brake caliper assembly that isn't present on the 89-92 cars. According to the above, it can just be removed.
The early disk axles had weights on the caliper, too. At least, the axle I took from an '84 TA does!
How important are those hunks of metal? Would I be really sorry if I, say, cut them off? they may not amount to much, but any reduction in unsprung weight helps, right?
Hope this help a little.
www.88irocarmy.worldbreak.com
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
It was a disc setup 9 bolt, the holes for the caliper and the backplate were just slightly different, might be able to make it work.
Car: 93 240SX
Engine: LQ9
Ok, now after i grabbed the set of earlier brakes in my garage that i bought under the impression that they were the 89-92 off someone here, they seem to bolt right up to my backing plates, so im guessing i have 88 backing plates huh, i'll bet the 89 up ones DO fit, now if i can only find a set of 89 up plates for 9 bolt, anyone got a set ?
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
<font face="Verdana, Arial" size="2">Originally posted by Z28racer:
now if i can only find a set of 89 up plates for 9 bolt, anyone got a set ?</font>
hahahahahhahhahahahahahhahahahhahah Good Luck!!!! Out of stock and discontinued... All you can do is try to find some off somebodies classified ad or hope to get lucky at a junkyard.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Car: 93 240SX
Engine: LQ9
<font face="Verdana, Arial" size="2">Originally posted by Brian Shaughnessy:
</font>
</font>
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
