Struts installed wrong?
Old Feb 25, 2011 | 06:43 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just put a set of Bilstein struts on my car along with a set of UMI's caster and camber plates when I finished my C5 brake conversion. I am unsure about one thing though. Where the rods from the struts stick up through the strut mount, the one on the driver side sticks up about 3/4 of an inch higher than the passenger side one. What is causing it to do this? I can get pictures if needed.
Old Feb 25, 2011 | 07:16 AM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
Re: Struts installed wrong?
Any chance the springs are not seated correctly? I had that happen once. Of course with that, there would be a small difference in ride height from side to side that would be measurable.
Old Feb 25, 2011 | 12:50 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How can I tell if the springs are seated correctly? Should they be sitting against a certain spot on the control arm?
Old Feb 25, 2011 | 01:12 PM
Guest
Guest
Posts: n/a
Pictures of the top of the strutmount, and the underneath of the strut mount please. I am assuming from your statement that you have everything bolted in place already since you say "I just put a set ...on"
Old Feb 25, 2011 | 02:35 PM
87350IROC's Avatar
Car: 87' IROC
It sounds like the one strut didn't get fully seated on the bearing, so it isn't poking through far enough. Pictures would help.
Old Feb 25, 2011 | 02:38 PM
Guest
Guest
Posts: n/a
My thoughts exactly
Old Feb 25, 2011 | 02:57 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Here are a few pictures I took.
Attached Thumbnails Struts installed wrong?-dsc04635.jpg   Struts installed wrong?-dsc04636.jpg   Struts installed wrong?-dsc04637.jpg
Old Feb 25, 2011 | 03:03 PM
Guest
Guest
Posts: n/a
I need to see up inside the bottom of the strut mount. You have something not allowing the drivers side to insert fully into the bearing
edit, opps- went bavck and looked at the pic again- Ment the passenger side is not correct.
Old Feb 25, 2011 | 03:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Here is the best shot that I could get.
Old Feb 25, 2011 | 03:28 PM
87350IROC's Avatar
Car: 87' IROC
How does that dust boot attach to the top of the strut? I know there was no way my stock ones would work with the Koni's. Maybe the boot is preventing the strut from seating.
Old Feb 25, 2011 | 03:38 PM
Guest
Guest
Posts: n/a
You will have to pull the dust boot out of the way. It should pull right down or else like 87350iroc stated you may have it caught in there somehow.
Old Feb 25, 2011 | 03:41 PM
Guest
Guest
Posts: n/a
You can see how the strut shaft goes flush against the bearing underneath. If it is not sitting flush against, or has a washer ofr something not intended in there under the boot then most likely your problem lyes hidden under there.
There is a thicker stepped portion of the shaft , then it narrows of course as it channels through the strut mount bearing. You can see the thick section of strut shaft in the pic I list below.
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
