koni's installed is this correct?
Old Mar 27, 2011 | 09:29 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
today I got around to putting the springs and control arms in as well as the front koni struts but I put the supplied washer and bolt on with a set of j&m caster plates and I'm worried the bolt cant get enough thread.
I snapped a few pictures
Old Mar 28, 2011 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: koni's installed is this correct?
maybe use a thinner washer under the locking nut.
Old Mar 29, 2011 | 03:17 PM
1988-305-tbi's Avatar
you arent using the factory dust boots are you?
Old Mar 29, 2011 | 03:24 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
if the car is still up in the air, put it on the ground partially to push the strut up more and thread it down.
Old Mar 29, 2011 | 03:36 PM
Twin_Turbo's Avatar
Remove the factory dust boots
Old Mar 29, 2011 | 10:44 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
It just has a some after market dust boots, just rest at the top they arnt between the strut mount and the strut.
as for lowering the car to push the strut up further I put the struts on before anything else.
On the opposite side I took the space/washer out and it looks much better, is there any harm in doing this?
Old Mar 30, 2011 | 09:53 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
taking it out completely MAY cause some friction, or so id think.
get a thinner one...as said above
Old Mar 30, 2011 | 09:32 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
What is the right dust boot to use with the Konis?
Old Mar 30, 2011 | 09:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Are you referring to the black cover that goes over the strut (seen in the wheel well) or the dust cover that sits on top of the strut mount (seen with the hood open)
I re-used my stock wheel well dust covers on the Konis. Seemed to fit fine. I don't think you can use covers on top of the aftermarket strut mount setups.
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
fasteddi
Sep 2, 2015 10:29 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
