Just installed my new LCARB`s and still cant get traction, whats next?
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
I just installed my LCARB`s on my car hoping that it will help with my traction issues and it diddnt seem too help too much from a dig, but i can tell a little difference from a rolling start. what would be the next best thing too replace and realy feel a difference?
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: Just installed my new LCARB`s and still cant get traction, whats next?
What tires are you running? Those will help more then any suspension product purchased. LCARB do not guarantee traction.
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
tires and shocks i guess
best regards
best regards
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
You still have a stock torque arm? An adjustable one will increase traction as you can fine tune your pinion angle.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
what tires and shock are you using? this is rather important
sorry it took so long too get back too you guys, i just went and baught a set of nitto 555r radials and it made a huge difference. But im still spinning the wheels thru first and part of second and still running stock shocks and springs, also i have not upgraded my torque arm yet because im not sure if its worth the money or not? what would be a better upgrade shocks or torque arm?I have a set of 3.73 gears that i want too put in but i cant even get traction as it is.
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i can tell you that bmrs torque arm, kyb gr2 front struts and kyb gas a just in the back and the prokit lowering springs really helped me traction issues....
aftermarket torque arms can add anti-squat and help hit the tires harder if they are shorter than the stock arm. pinion angle wont help traction any.
Engine: gone
Transmission: gone
Axle/Gears: gone
deffinately need to change the shocks. I run the KYB gas a just's they helped me. I know a shorter torque arm helps traction. Im sure a stiffer one would too. I have not upgraded mine but I will as needed.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
