which rear springs iroc or rs
Car: 1992 rs stock for now
Transmission: auto
i have a 1988 iroc camaro rear end im swapping into my 92 rs which sponges should i us i have the springs from the roc arethey better than the rs also i don't have roc springs for the front will it affect the the ride height in the rear cause e the roc springs a noticeably shorter than the rs thanks for the help
Received 1,679 Likes
Re: which rear springs iroc or rs
Which is "better"; monkey poo, or elepahnt poo?
They're all garbage. Just some old wore-out stock springs that weren't much good in the first place.
Sounds like the IROC ones have more miles on em, maybe with worse shocks so they got continuously bent back and forth more, and are therefore the more wore out of the 2. Doesn't matter; throw em all in the trash.
Go to the store and get a pair of Moog/TRW CC635.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
New springs are about $60 for a set. Not much point in putting old ones back in.
1 Post
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
9 bolt rear ends are actually stronger though not by much and parts are extremely hard to find to the 9 bolts (and much pricier). my choice would be a 10 bolt of course.
All 9-bolts have 28 splines regardless of year. The 10-bolt wasn't equipped with 28-spline axles until 90 (though some may have crept in in late 89). Most would agree that the 9-bolt is somewhat stronger. Here are a couple of informative links that may shed more light:
https://www.thirdgen.org/forums/faq-...now-about.html
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
sailtexas186548
08-26-2015 03:32 PM
mustangman65_79
08-11-2015 03:17 PM
