Wonderbar
Old Dec 22, 2011 | 10:12 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Wonderbar
any of you guys have one of Spohn's adjustable/pre-load wonderbars? Was really wondering if it was worth the extra cost for it considering you can grab a UMI/BMR one for $42 now. It's the only part I haven't upgraded and I figured adding this would go along nicely with the strut tower brace.
Old Dec 22, 2011 | 10:29 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Wonderbar
hmmm thats interesting I would like to know too, why would you need that to be adjustable?
Old Dec 22, 2011 | 10:39 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Wonderbar
I don't see the point personally. And the Spohn Wonderbar has a reputation for poor fitment. Stick with the TDS version. You'll like it.
Old Dec 22, 2011 | 10:48 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
Have a link to their site? I saw a few threads about it, but I've never bought from them.
Toxic, apparently it helps with stiffening things up a bit. I'm not sure if it's a gimmick or what, though. They're the cost of two wonderbars.
Nvm, I think it's TopDownSolutions from a google search.
Old Dec 22, 2011 | 11:28 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Wonderbar
Top-DownSolutions.com. Or just click on the TDS link over there--->
http://www.top-downsolutions.com/ste...bird-p-45.html
Lon Salgren
Old Dec 23, 2011 | 12:05 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: Wonderbar
tds= amazing
delta- like it stiffens it up more that the stock wonderbar?
beacuse the stock one felt stronger than the aftermarket one i boght.
Old Dec 23, 2011 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Wonderbar
I'd suggest after market strut mounts with spherical bearings before adding the STB.
If you'd like more info about the adjustable piece from Spohn, there's a write-up on his site.
toxik, you don't mention which after market bar you purchased, but I'd think that most would be considerably stronger than the stamped OE piece. Long ago, I bought an OE bar, which was slightly bowed. To correct it, I simply put it between two 2 x4's and put a bit of my weight on it.
JamesC
Old Dec 23, 2011 | 03:41 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
JamesC
Already got that covered. Went with J&M/Hotparts.. just got them yesterday, actually.
Old Dec 23, 2011 | 04:39 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Wonderbar
whos going to be the first to make this stuff from Alum.
strut tower brace also.you going to drop $50 might has well be $100
Old Dec 23, 2011 | 09:00 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
Already have the Edelbrock 3 point. That came in earlier this week. The wonderbar really is the only thing I have left that hasn't been replaced.
Old Dec 23, 2011 | 10:58 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Wonderbar
I always considered a Edelbrock 3 point brace but have to change my open element back to stock every 2 years to pass CA smog. Kind of figured it would be a pain removing and installing it on a regular basis.
Old Dec 24, 2011 | 07:12 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
Originally Posted by ronusmcmma
I always considered a Edelbrock 3 point brace but have to change my open element back to stock every 2 years to pass CA smog. Kind of figured it would be a pain removing and installing it on a regular basses.
There's not really a whole lot of hardware with it. It'd probably only take 15 minutes to take it off. It's the initial setup that takes awhile from the looks of it. Either way, you can't buy Edelbrock braces new anymore anyways so.. yeah. I really hard to look hard to find mine new. Called literally 8 places. Not a fun experience.
Old Dec 27, 2011 | 12:30 AM
Xanath's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock 305 CFI
Transmission: CPT Ultimate 200 4R
Re: Wonderbar
...Either way, you can't buy Edelbrock braces new anymore anyways so.. yeah. I really hard to look hard to find mine new. Called literally 8 places. Not a fun experience.
I would assume this is because they sold off the entire suspension facet of their business to QA1 recently...? I bet if you checked with them they probably do or will carry it on their website, just rebadged as a QA1 piece now.
- Xan
Old Dec 27, 2011 | 12:39 AM
lonsal's Avatar
Re: Wonderbar
I'll share two things. First, it is not much of a pain to remove the brace. Just two bolts and two screws & nuts at the firewall.
Second and better news. You don't even have to remove it to swap from an open-air element to the factory stock. It is not in the way at all.
Lon
Old Jan 1, 2012 | 01:49 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
Lon
Went ahead and placed an order through you. Spent a little more than I anticipated, but that's alright.
By chance do you know the hardware size for the wonderbar? I'd like to replace them since a new part is going in.
Old Jan 1, 2012 | 03:17 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
Re: Wonderbar
I don't know if it made much difference but I took a stock wonderbar and clamped both ends down on a bench, cut out the hollow tube and welded in a solid piece of round stock steel with the same diameter.
Old Jan 1, 2012 | 04:15 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Wonderbar
I would have to wonder if this would place more stress on the new welds you made since you essentially cut it and altered it. I can't answer this one, though.
Old Jan 1, 2012 | 05:22 PM
irocarter's Avatar
Car: 89 iroc
Transmission: wct5
Re: Wonderbar
Good question Delta.
I have also welded solid every seem under the hood, from the crossmember to the core support.
Old Jan 2, 2012 | 10:59 PM
R/T-Z28's Avatar
Re: Wonderbar
Ill have to get one pretty soon
Old Jan 2, 2012 | 11:07 PM
lonsal's Avatar
Re: Wonderbar
http://www.top-downsolutions.com/hea...56122aadf6bcde
Lon
Old Jan 22, 2014 | 12:36 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
Re: Wonderbar
UMI Performance makes some pretty awesome stuff, you guys should take a look at all of their suspension products for our cars.
umiperformance.com
I'm picking up a new wonder bar, tubular pan hard bar and rear control arms with greasable polyurethane bushings. Not horribly expensive either
Old Jan 22, 2014 | 03:23 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Wonderbar
+1 I went with TDS because of the third bolt hole. I doubt it makes a difference over UMI/BMR but WHAT IF IT DOES?!?!?!
I have them in my car. i would buy founders today since the designs were identical until founders improved theirs. https://www.thirdgen.org/forums/susp...-improved.html The plates are made by the same person. If you search you'll find a thread where a guy bought one brand and got the other brands sticker on one on accident.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
snakeshooter
Sep 10, 2015 07:46 AM
toosloz
Carburetors
Dec 12, 2001 12:02 PM
