grinding noise when turning
Old 11-28-2012, 09:36 AM
richsteve's Avatar
Hey guys, when I turn the camaro hard over right or left I am hearing a grinding noise. It did it bad this morning when it was cold but seem to stop when it warmed up and got going. Any idea what it could be? Thanks
Old 11-29-2012, 02:41 AM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 5 speed manuel
Axle/Gears: 3.08
Re: grinding noise when turning
Could be low power steering fluid, bad wheel bearings, worn tie rod ends, worn brake rotors, CV joints.
Old 11-29-2012, 08:06 PM
richsteve's Avatar
Hey thanks for responding. Yeah that is what i am thinking too. I will check the power steering fluid this weekend and will check it into the shop if that doesn't do it. Thanks again
Old 11-30-2012, 01:14 AM
arod231's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.08
Your welcome
Old 12-06-2012, 02:19 AM
tagolf2000's Avatar
Car: 1987 IROC
Axle/Gears: 2.73 Now 3.42
CV Joints? on our cars?
Well could be some of those that were mentioned. Does it sound like it is coming more from the front center or rear of the car? Mine did that and it sounded like it was coming from the front at first but then sounded like it was more towards the rear or center. It turned out to be the rear end fluid being low and needed to add limited slip addative too.
Old 12-06-2012, 11:46 AM
richsteve's Avatar
Hmm....interesting point tagolf2000. It seemed to be coming from the front but only would do it every so often. I went to my mechanic and they check everything out on the front suspension and said everything was good and tight. Couldn't reproduce the noise either. When I brought the car home I checked the power steering and it was extremely low (Not even showing on the dip stick). So I added power steering fluid and it seemed to help it out so I think I am in the clear for now. If I hear the noise again I will definitely listen to see if is coming from the front or rear. Thanks for the insight!
Old 12-06-2012, 01:12 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Since the power steering fluid was low, you might want to check for leaks.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
83 Crossfire TA
01-03-2016 01:26 PM
Jorlain
10-08-2015 01:57 AM
GouldyGTR
09-07-2015 09:05 PM
andy74
09-03-2015 08:41 AM
Quick Reply: grinding noise when turning
