center link on right or wrong?
Car: 91 Camaro
Engine: 383 carbed/headers/nitrous
Transmission: th400
Axle/Gears: Chevy 12 bolt w/411 gear
I have been rebuilding my front end and re-installing everything back and I put the center link back what i thought was the right way but know that I am looking at it and a few picks of other cars it seems to be backwards. My question is does it matter which way it sits their seems to be full range of steering? any help would be greatly appreciated.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: center link on right or wrong?
Here is a pic of my newly installed center link. I am the second owner of the car and have owned it since it had 67,000 miles. I believe that it had the factory original bar. I replaced it in exactly the same position with all new components and it is angled forward and up. I believe that if it were angled backwards and down it would hit the oil pan. I'll look for some internet pictures to see if I can confirm I am correct, but for the last ten years that I had owned the car with the bar like that it steered fine and had been aligned.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I guess that's a better description.
The tie rod nuts will be on the front side of the centerlink. I know mine is flipped around to get a little more clearance because I have my engine lowered and the tie rod nuts are on the backside. I'm not worried about the Ackerman angle since the only turns I do are at the end of the dragstrip.
Car: 1991 Z28 Vert
Looks like a few pictures here that have the bar as I described mine: https://www.thirdgen.org/forums/susp...-swap-any.html
http://www.facebook.com/photo.php?fb...type=3&theater
Car: 91 Camaro
Transmission: th400
Thanks for the replies mines is on wrong I'm going to probably flip it around because I'm getting a lot of shaking in the front end ill post back after another alignment
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Car: 1991 Z28 Vert
Car: !991 RS Camaro
Axle/Gears: 4.10 4th gen
Mine are flipped backwards too. Never had a problem and I know a few others who run their's backwards also.
Car: 1991 Z28 Vert
Car: 87 IROC L98
No but my car also isn't street driven. Mine is flipped over and like the above post says, it allows more engine clearance. I have my engine sitting as low as it can go. My header tubes wrapping around the front suspension actually keep me from dropping it down a little more. One tube also wraps over the right frame rail. I'd love to drop the front of the engine at least another inch but that would mean a custom made set of headers.
As I mentioned above, flipping it over may change the Ackerman angle. That's when the inside tire turns sharper the the outside tire. Since my drag car turns very few corners, it's not something that affects me. I also have 27.5" tall front tires so I installed some different steering stops to keep the tires from hitting the inside fenders. This reduces my turning radius.
Car: !991 RS Camaro
My car is a DD but when I did the ls swap the a/c was very close so I flipped it for more room. I've never had a problem with it but if your car doesn't need the extra space I would but it back like it goes.
Car: 1991 Z28 Vert
Nice and interesting to know! But, yeah, I don't need the room so I plan on keeping mine in the stock position.
Car: 1991 Trans Am GTA
Engine: 350 carbed
Axle/Gears: 7.5 10 bolt 4.10
Car: 91 Camaro
Transmission: th400
Responding back to rich no this weekend I'm going to change that and the steering box there was play in the idler arm I just did have the money to do everything hopefully the idler is the culprit
Engine: 305 TBI
That's what was wrong on mine. I replaced the idler, got a front end alignment, and no more shake. Good luck
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
