did the step by step now what?
Old Mar 15, 2013 | 08:57 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
I went through the tutorial with pics and had my tilt steering down to the nub...come to find out the entire shaft moves in and out about an inch..where do I fix that ?thanks
Old Mar 16, 2013 | 02:13 PM
Re: did the step by step now what?
You just put it back together. The parts you have out of it, hold that other still.
Old Mar 16, 2013 | 03:51 PM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I just did mine this weekend also.
Once its back together all will be fine. Mine is like a new steering column now!!
I did have to buy the tool to get it back together though.
Old Mar 17, 2013 | 06:48 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Thanks, it sounds like a really good plan....next part I didn't mention. This new project I am engaging, is an 89 GTA that came partially assembled(including many missing parts) It has the radio components in the steering wheel which have been mutilated and the stereo is gone. If I go with a custom steering wheel how do I get the horn button to work?(all the wires and not sure which controls the horn).
Old Mar 17, 2013 | 09:22 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
here is the schematic for the horns out of the 88 manual. Should be the same in your car.
Old Mar 17, 2013 | 12:10 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Thanks, but still a major glitch. It looks like all the pieces are there but when I put the spring retainer onto the shaft I am 1/4" away from the steering lock plate. I have no idea what thickness the plastic piece was that goes on first is and maybe that is why it was apart when I bought it. Is there a rebuild kit a person can buy? The 4 inverted torx weren't really loose but I snugged them up anyway after tearing it down that far.
Old Mar 17, 2013 | 01:30 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Have to ask but as I said this was apart when I bought it. I tightened the steering wheel until it bottomed out on the shaft and there is still over 1/2" between the bottom of the steering wheel and the housing......Is there a piece missing I am unaware of?
Old Mar 17, 2013 | 01:32 PM
rawley2's Avatar
Use red loctite.. Its easy now,, You don't want to do that again in a couple of years.
Old Mar 17, 2013 | 01:35 PM
rawley2's Avatar
Not sure. I started with my original one.
You did say something about radio controls and you not having them. Maybe the wheels are different?
I really don't know.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Elephantismo
Feb 13, 2019 12:51 AM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
Chad Speier
Sep 24, 2015 12:32 PM
