UMI and Alstons installed at Schwartz Performance
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Pics coming soon..
The UMI and Alston SFC combo-
I have heard that some say it makes the car feel stiff. Yes it does, but it also allows the car's suspension components (i.e. shocks and springs) to fully work to their potential.
The ride feels "Cadillac" like. Yet you still have greater authority in the turns... THe car does turn with more confidence, it seems to take less effort.
Keep in mind that I had Koni's installed in the back and front along with moog 5665's in the rear.. (still need to get to the fronts, but frankly, im no hurry, the car is so much better now I just want to enjoy it) and this car rides so much different. Much different than with the Koni's alone.
I believe that the SFC's have made the Koni's do what they are supposed to do. Give a great ride and handle well. The SFC's exponentially increase ride quality and handling. Period.
Jeff said they had issues with fitting the Alstons on the passenger side, near the cat. Common install issue. But they made it work. It looks naturally attached to the vehicle. Like its always been there.
VERY happy with the results.
Chuck
Chuck
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Re: UMI and Alstons installed at Schwartz Performance
I've got Spohn SFC's installed and a set of Alston's in the trunk awaiting install... T top car, should be good with Bilstiens and other aftermarket upgrades
Stand by
I am now a firm believer that all 3rd gens need this. First thing. Wish I did this when I bought the car.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yea, you can see its not all the way up on the frame, I had to use a 2nd jack to get mine in nice when doing them. you can see its not tight to it in the pic.
on top of they were already under there to weld in the others, why not the alstons too? The others welded in already bumped you up into the higher race classes, weld those two while your at it bro, here's a 12pack.. is what id say. more so since they got a lift, so its easy.
they are both bolt and weld in design......
Thanks for the input !
I thought that those Alstons should have been welded....they do look about as low as the exhaust pipe, so getting them up tighter would be good
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
from the pic I posted of yours, I really question that rear bolt and if its even through the side of the frame section or partialy sliced through the bottom. like the alstons, that part of the frame angles up.
Instead of bolting the alstons on, jack them up tight against the frame and weld the holes in with plug welds like this
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Chuck84TA,
Nice job with the selection of parts and I really like the UMI SFC.
that's what I will be using. You're definitely doing all the right things with the right parts and it looks great. As far as the Alstons being refitted properly and welded well that's just a small snag that can be fixed in about 5 minutes. Over all you're doing a great job.
Side note = Man I hate those scissor lifts. I took my car to a reputable shop to have some work done and I come back to see that they were clueless as to where to put the front pads. Crushed the sides of the car even severely cracking a side ground effect.(brand new custom paint). Even the pad in the photo above on the SFC makes me cringe .Way to close for comfort .
Thanks Ron!
I still cant get over how well this car rides! And I am using stock sized for 15X7 wheels all weather Goodyears to boot! Now I really want bigger tires!!!
You'll love the setup!
Oh, and the Eaton Posi...Good Call!!!
Thanks for the pics of the welds guys!!! Joined: Jun 2000
It's not a scissor lift, it's a 2 post and it's not a problem lifting these cars. The pads are adjustable, there's plenty of clearance.
Sure beats rolling around on a creeper on the floor.
When it comes to welding the Alstons, do I need to pull the carpet out so as to not have burn marks/holes?
Engine: TBI,5.0
OK, 2 Post. Thanks for the correction .Terminology is important with me.I did a little looking and found that the drive on lift is called a 4 post. Correct ?
I should have been more specific .Its not the 2 post that I have problems with, its trusting a mechanic to know where the lift spots are with a unibody such as mine. My trust issues with mechanics was bad enough so when they don't know you have to get down on the ground preferably with a flashlight and find the exact spots on the unibody for the pads to be placed it pissed me off. Then they acted like its no big deal.
Sorry Chuck84TA
Sorry Chuck84TA
They do take more time to set up than a 4 post, that's correct. A mechanic works on the clock and you are right, most just kick the legs under the car and start lifting. A lot of cars have crushed underbodies from this
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
