front end clunk
front end clunk
i have a 1991rs it has a clunking in the front end. it seems to be near the passenger side foot well. it happens under hard accel and decel . it tends to happen more while turning but happens in a straight line as well. the car has new tie rods, ball joints , struts and sway bar mounts. none of this has made any improvement. im at a loss. any help from the sages here at thirdgen?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: front end clunk
For the heck of it, check the transmission and/or torque arm mounts.
JamesC
JamesC
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: front end clunk
Broken spring or worn a arm bushings.
Sometimes it can be hard to see the broken spring if just the tail end is cracked.
Almost certainly need new bushings on the aarms by now.
Re: front end clunk
I was hoping it wasn't the a arm bushings . They are still there but look a little tired. I was hoping it was something else that i was overlooking. But im beginning to think you are correct
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: front end clunk
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: front end clunk
jack it up at the control arm and check for play in the wheel holding it at 12 and 6. a little play in the bearings is normal, but significant play can be from a bad strut, bj, mount or loose strut bolts.
check your idler arm by trying to move it up and down by hand. any movement is cause for replacement.
with it on the ground, have someone turn the wheel while you watch the box and linkage for anything obviously moving incorrectly.
Re: front end clunk
K-member = the piece that the engine sits on and the front lower control arms are bolted to
Sounds like your K-member bolts are loose.
Terrell351
Jun 13, 2021 01:13 PM
