UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
Old 08-01-2014, 12:35 PM
UMI Performance's Avatar
Bolt-in Rear Shock Relocation Brackets for the 1982-2002 GM F-Body
P/N 2047 priced at $39.99/set
UMI Performance, Inc is proud to introduce our P/N 2047 GM F-body bolt-in rear shock relocator kit. This kit rotates the factory style rear shock to reduce the common problem of lower shock mount binding. The shock is relocated to a double shear mount and pivots freely about the lower bolt. An innovative, TIG welded lower bracket holds the shock in double shear and works with standard axle mounts as well as with most common relocation brackets (spacers included). Drilling two 3/8” holes is required (no welding). The P/N 2047 kit accommodates a standard 1-1/4” wide shock mount and has ½” diameter mounting holes. Hardware is included. All UMI components are 100% manufactured in Philipsburg, PA-USA.
1982-2002 GM F-Body Rear Shock Relocation Kit, Bolt In
Old 08-01-2014, 03:16 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
Sounds like a good idea. Can you get a picture of one installed?
Old 08-01-2014, 03:40 PM
Hello,
This is basically a sub-component of our coil over conversion kit so if you check out the link below there is quite a few pictures.
http://umiperformance.com/catalog/in...roducts_id=783
Thanks for looking
Old 08-02-2014, 11:57 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
whats the top half of this MT kit go for??
Old 08-03-2014, 10:43 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
What's the distance between the top and bottom shock mounting bolts on a stock height set up? How much does the bottom bracket lower the mounting location?
Old 08-03-2014, 10:22 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Could be promising, but it doesn't look like it lowers the shock mount.
Looks similar to what Matt (mw66nova) did - his pic attached. This looks to just help with some possible "bind", not lowering the mount point. The 'tongue' would be longer, if it lowered the mount point.
Attached Thumbnails UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid-matts-shock-reloc.jpg
Old 08-04-2014, 08:06 AM
Hello,
We don't have a part # to sell those separate but I am sure we could do it. Price would be $89.99.
Also as mentioned above this isn't a shock lowering bracket. It just rotates the shock 90 degrees to prevent shock binding. It leaves it in the same location.
Thank you,
Old 08-04-2014, 10:56 AM
Originally Posted by UMI Performance
Hello,
Thank you,
$89.99
ill add a set to my K Member order. ya guys are making me..
Old 08-04-2014, 11:32 AM
$89.99
Sounds great!
We have a current order now I should add it to?
Old 08-04-2014, 02:37 PM
RavenGT's Avatar
Car: 1996 Firebird
Engine: 3800 Series II
Transmission: 4-speed Manual w/ OD
Would you explain how the existing shock mounting binds?
Wouldn't this configuration create shock bind if the axle is not parallel to the chassis - like hitting a bump??
Old 08-04-2014, 03:13 PM
Sounds great!
yes..i called a few min ago and just did a 2nd order for the upper mt's.
was going to add it to my K member order. but it's due to ship out in 2 days.the 6th
and did not want to slow it down..as ya have to make them..
so just did another order..
thank you UMI
Old 08-04-2014, 05:25 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
There's not much point in using this set up unless you replace the stock rubber parts with spherical bearings. That's what gets rid of the bind. Hence my questions. These brackets just make the installation easier and look pretty cool too.
Old 08-05-2014, 12:18 PM
in my case. im swaping out the stock set up for rear coil overs.
and wanted a larger pad. inplace of the springs.
i have the 1QA rear coil over set up. And the kit they sell has a smaller pad for the top Mount. Im sure its fine. But I wanted to make sure..peace of mind. sort of thing.
my car is stock height. With 28inch tall 13 inch wide tires tucked under..325 50 15 Mickey Thompson drag radials. Any other time I run Mickey Thompson sportsman pros 12.5 29 15
customblackbird
08-15-2021 10:16 PM
LT1Formula
11-16-2015 01:13 PM
sweet_87_iroc
09-25-2015 10:01 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
