front control arm question
Old Mar 30, 2015 | 08:16 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Transmission: GTO T56
Axle/Gears: 3.73 S60
When removing the old control arm bushings I accidentally cut too far and got into the control arm a bit. My question is at what point is the control arm trashed and need to be replaced? Is there a way to fix it?
Old Mar 30, 2015 | 11:23 PM
Debased's Avatar
Car: 92 rs sorta white
Engine: L33 5.3
Transmission: Ctsv t56 converted to fbody
Re: front control arm question
Would really need pics to tell.
Old Mar 31, 2015 | 12:51 AM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
This ones the worst, sawzall cut a little deep on the one end
The other control arm I cut through the ring a little but that's the only spot
Old Mar 31, 2015 | 12:31 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
i'd junk them and get different ones.. you destroyed the tension on the interference fit that holds things in place, and i wouldn't want to weld on it there any potentially weaken it more.
Old Mar 31, 2015 | 05:42 PM
Debased's Avatar
Engine: L33 5.3
I agree wouldn't want to risk it. I mean may hold but if it fails losing a control arm at speed wouldn't be fun.
Old Mar 31, 2015 | 07:59 PM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
Alright, sounds like I'm junking them. Thanks for the help
Old Mar 31, 2015 | 08:07 PM
They're SOOOOOOOOPER common; must fit some other chassis, like S trucks or something. Whatever it is, whenever I've wanted a pair, the junkyard already has a stack of pairs of em pulled and sitting on the shelf, and they're CHEEEEEEEEEEEEEEEP. So cheeeeep in fact, that it's better to buy a set and swap new BJs and bushings into em BEFORE tearing down the car, so the actual R&R takes less time and has no risk
Old Apr 1, 2015 | 10:02 AM
gertie3993's Avatar
Car: 86 Z28
Engine: '06 LQ4
I just don't want to go through the trouble of pressing in the bushings again, shops around me want $200 to do it. For the money I'm thinking I can just get the tubular control arms and be done with it.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
