87 GTA front sway bar bushing question
Old Apr 2, 2015 | 12:51 PM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
We have a 1987 GTA and I need to replace the front sway bar bushings. I've looked on the local auto parts website and they list several sizes.... 1-1/8", 1-1/4", 1-5/16" and 1-7/16" sizes.
Would any of you guys happen to know the size ??
Old Apr 2, 2015 | 03:42 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 87 GTA front sway bar bushing question
Depends on what you have on your RPO codes, if available. Look for an F41, FE1, FE2, or FE3. Go to the thread below and match the code with the year to find out your size in mm. If you have calipers you can check the diameter of the sway bar in question. I believe you may have the FE2 - 34mm front and 24mm rear.
https://www.thirdgen.org/forums/faq-...-sway-bar.html
Old Apr 2, 2015 | 03:57 PM
Engine: 5.0 TPI
I saw that thread earlier today....
The problem is, the auto parts store (Advance) doesn't list the bushing sizes in mm. They show up in inches like I posted.
Old Apr 2, 2015 | 04:10 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
google in. to mm. and convert it!
Old Apr 2, 2015 | 04:19 PM
Engine: 5.0 TPI
tried that earlier but I went mm to inches....
I'm thinking 34mm bushings.
Old Apr 2, 2015 | 04:35 PM
antares57's Avatar
34mm bushings are 1.34 in per my calipers. Probably looking for 1 3/8".
Old Apr 3, 2015 | 10:54 AM
SOCAL-Z's Avatar
Car: 87' IROC
I just bought Energy Suspension 34mm greaseable bushings for my 87 IROC last week they have a zerc fitting for adding grease.Ordered online as my local stores did not carry the right size part. Part number is 9.5167G for black and 9.5167R for red. Size is 1 5/16" for 34mm. I also bought Energy Suspension greaseable bushings for the 23mm rear swaybar part number 9.5159R. Energy Suspension sway bar end link part number is 9.8117G for black and 9.8117R for red . Front and rear bars use the same size end links.
Old Apr 3, 2015 | 01:02 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
grab a big crescent wrench... tighten it around the sway bar in the car... measure the jaws with a tape measure.. get bushings about that size.
Old Apr 6, 2015 | 11:52 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
There are no aftermarket bushings that will fit a 36mm bar. 34 is as big as they go. The only place to get correct 36mm bushings is TDS.
http://www.top-downsolutions.com/cha...ro-or-firebird
Old Jul 12, 2015 | 01:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
3.5213R energy suspension fits 36mm bar
Old Jul 13, 2015 | 07:47 AM
UMI Sales's Avatar
We offer sway bar bushing sets in 1 3/8", 1 1/4", 1", 7/8" and 3/4" that are completely greasable, and come with a unique channel design that allows lube to get to all inner bushing surfaces.
If you have and questions or need help give us a call.
Craig
Old Jul 14, 2015 | 12:08 PM
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
I bought a set of 36mm bushings from Summit racing a few years back when I replaced mine. Energy suspension made em.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
