Rear sway bar install
Old Mar 25, 2018 | 02:40 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Axle/Gears: soon 4th gen 3.23 w/ Posi
So, my 85 from the factory did not come with the rear sway bar (Sport Coupe model) Now that I am able I'm really working on my camaro and going through and upgrading where I can. Went to the salvage yard and they had a 99 firebird and it had the rear sway bar. So i pulled the bar and all the hardware (link mount brackets, ubolts) however when I went to go install on my car, even though the holes are there for the bracket I found the holes weren't threaded. Has anyone else run across this? I was just gonna tap the holes with a 10x1.50 since that was the size of the bolts from the donor. (obviously I will use new hardware.)
Old Mar 25, 2018 | 03:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear sway bar install
I've seen that before, just tap the hole and don't look back
Old Mar 25, 2018 | 03:18 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I'm not looking at my car but I don't recall threaded holes.
I think my '89 has metal tabs at the body and the sway bar bushings sandwich the tab in the middle. My memory could be flawed.
Old Mar 25, 2018 | 03:28 PM
Heitzman's Avatar
Car: 1983 Z28 Camaro H.O.
Engine: 305 H.O.
This is how my rear sway bar is mounted.
Old Mar 25, 2018 | 03:44 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Sorry, should've clarified, I meant the bracket that bolts to the body and has the sway bar link running through it. And yea, thats what I was planning on doind, just tapping the holes and being done with it. Just didn't know if anyone else had done it and what size bolts/tap they used.
Old Mar 25, 2018 | 03:47 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oh, I think I understand now. He's got to attach the upper bracket to the subframe.
Old Mar 25, 2018 | 03:50 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
yes, that bracket. sorry, wasn't sure what to call it.
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
LOL! Beat me to the punch. You posted up while I was writing.
Old Mar 25, 2018 | 03:54 PM
Heitzman's Avatar
Engine: 305 H.O.
My rear end links had a bolt that ran through the bushings and a nut at the end. No threads on the body. Bolt, washer, bushing, sway bar, bushing, washer, sleeve, washer, bushing, body mount, bushing, washer and nut.
Old Mar 25, 2018 | 04:00 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Looking in my '88 service manual, the torque spec is 47 Nm (35 lb-ft) so yes, that corresponds to an M10 or 3/8" bolt.
Old Mar 25, 2018 | 05:01 PM
NCcowboy's Avatar
Car: 85 sport coupe
Engine: 355 sbc
Thanks man, greatly appreciate it. I was gonna go with the 3/8" but it went in with out traction before even trying to tap it, but the M10 won't even try to go in, so I'll just go with that.
Old Mar 25, 2018 | 06:01 PM
Drew's Avatar
8.977 BOLT, HWH TAP (M10X1.5X32) ............ 11504293
Based on the description in the Parts & Illustrations Catalog, I'm going to guess that's a Hex Washer Head self-TAPping bolt. The book implies a change in 91, but still lists a "TAP" bolt. Assume that means at the factory they lined up the fastener with the hole and zipped it in with a power tool. Probably a better deal to tap it at home.
chevyv8guy
Apr 8, 2013 09:30 PM
Steven6282
Mar 23, 2012 02:19 AM
vjo90RS8
Exterior Parts Wanted
Mar 15, 2007 09:54 PM
Blake
Jan 30, 2007 10:10 PM
89FormulaRoth
Nov 21, 2001 04:13 PM
