Type II power steering pump on an 87
Car: 1987 Trans Am
Has anyone converted to a type II power steering pump on an 87 before? If so, what pump, pulley and bracket did you use?
Thanks, Ryan
Thanks, Ryan
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
Re: Type II power steering pump on an 87
I have on an ‘86. I got a tough stuff type II pump and v-belt pulley from speedway, used their aluminum block mount power steering pump bracket and a universal remote reservoir. Had a local hydraulic hose shop build a simple 14”-ish hose with a 90* bend at each end to adapt it to the box. I may have had to use an adapter to connect hose to gearbox but don’t remember. Super easy swap. If you want the pn’s I used I’ll have to do a bit of research to recall them. It’s a nice upgrade for appearance and weight most definitely but made the steering very light even with the smallest restrictor on the box.
Yes, I want to know also.
Engine: 383 SBC
Tuff Stuff TC pump PN 6175AL-4 is what I used, others will work.
Sweet Mfg v-belt PS pulley 310 30026. Whatever pulley works for you depending on your belt setup, needs to be a press-on type with a .662” bore though.
PSC power steering bracket MB05K
KRC 91510000 looks just like the one I’m using but I didn’t pay $96 for mine. I don’t remember what brand it was but it was significantly less money. I think I used PSC for this too.
For a v-belt setup use Gates 7355 belt.
The pressure hose was made by a local hydraulic shop with the 90* 10AN female fittings because this pump outputs 1200psi and I made the bracket holding the reservoir to the cylinder head. Easy to make though
Engine: 383 SBC
I keep getting error messages while trying to upload my pics but it’s really straight forward on installation. Also know that the pump has a 16x1.5mm o-ring outlet port so you’ll need an adapter to AN if using this particular pump and an identical adapter on the gearbox. Tuff Stuff has some with 10AN pressure port fittings. The reservoir had AN ports on it so put AN to hose barb adapters to simplify the plumbing on the return and suction lines. Lastly, I did have to drill out one of the threaded mounting holes to run a bolt through to the block mount.
Car: 1987 Trans Am
SilverChicken, if you could get the pictures to work, I'd like to see how you mounted the reservoir.
Engine: 383 SBC
Hard to really see but it’s .125” sheet steel that uses the 3 bolt holes in the passenger side head and holds the reservoir level
Engine: 383 SBC
Here you can see the block mount. I bought the smallest orifice restrictor that had a 10AN male fitting available. It’s still overboosted for my taste. I’ll fix that suction line one day when it matters to me.
Engine: 383 SBC
In this pic you can see another part of the bracket I made for the reservoir and how it’s bolted to the head. I’ll get a cleaner shot of it later for you.
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
I got my pump and reservoir combo off a 2005 jeep grand Cherokee 4×4. I will grabs some pics today.
Car: 1987 Trans Am
Car: 1987 Trans Am
Car: 1987 Trans Am
Might it be from a 2004 Jeep? The pics I get from searching for a 2005 look like they feed from below.
Car: 88 IROC-Z
Nope mine comes out the right side. I had two pumps at the time so I might have swapped the reservoirs. Other pump was off a S-10 but it was a smaller shaft size and smaller volume pump. Thats why I went and grabbed the jeep pump.
Those pictures are worth 1000 words. See how much cleaner that pump is than the A can? And I bet it's easily adjustable too.
Engine: 383 SBC
TORN has me interested in his belt setup! I ran across somewhere that steel factory pullies have about a 400hp/6k rpm limit and I’ve well exceeded one and right at the other. Or is there any real validity to the hp limit? I could see how there is but never heard of anyone blowing their factory steel pullies apart either.
I don't buy it. Back in the day, 283 & 302 SB Chevys turned 8000+ rpm with steel pulleys. All GM ever did was make the 302 pulleys "deep groove" to help keep from throwing the belts off.
Car: 1987 Trans Am
Will the stock pulley fit on the 4th gen Type II pump, it appears to be a 19mm pulley? Or does anybody know how to get the pressed in reservoir nipple out?
Camaro kid97
Sep 18, 2014 01:18 PM
woody80z28
Dec 19, 2012 08:11 AM
